Go to Post Gracious Professionalism, it's hard to describe, but I sure know when I'm not living up to it. - rsisk [more]
Unread 17-02-2004, 23:05
Darksun Darksun is offline
Darksun is an unknown quantity at this point
Double Solenoid Leak
Hey, everyone. I've heard a lot of people talking about how they left out the groove bit when putting together their double solenoids to slow the leaking, which is what our team did, but has anyone actually gotten it to stop leaking all together? Also, is it legal to use old double solenoids? Thanks very much!
Unread 17-02-2004, 23:17
BoingB's Avatar
BoingB BoingB is offline
#0859 (BoInG)
BoingB is an unknown quantity at this point
Re: Double Solenoid Leak
Yea my team is having trouble with that also. Let me know if you get an answer.
Unread 17-02-2004, 23:23
Umm Errr...
Yes there is a rule that says you can use previous year's solenoids.
1139 Alumni
Unread 18-02-2004, 19:04
Thanks very much for the info. Now can anyone tell me if any team managed to stop the double solenoid from leaking?
Unread 18-02-2004, 22:52
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Where is the leak? If it is fittings, make sure you used the right wrap of teflon tape and that the fittings are tight.
Also, when you assembled the solenoids, did you use the thin or thick gasket.
Only the thicker one works.
We have not done a full leak check but I don't think we have leaks there.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Double Solenoid Wires Lord Nerdlinger Pneumatics 4 17-02-2004 19:54
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
double solenoid gail OCCRA 0 11-10-2002 19:42
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
