Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 15-02-2004, 13:16
reisser's Avatar
reisser reisser is offline
Ph.D. User
AKA: Brandon Reiss
#0103 (Cybersonics Technology Team)
Team Role: Animator
reisser is on a distinguished road
Send a message via AIM to reisser
Cybersonics 103 Animation Teaser...
on ChannelsUsed pCont do
pCont.useTime = true
pCont.useInteger = true
pCont.usePosition = true
pCont.useSpeed = true
on Init pCont do
count = pCont.NumParticles()
--random targets
for i in 1 to count do
pCont.particleIndex = i
pCont.particleInteger = random 0 23
on Proceed pCont do
--determine distance from origin (correct straying particles)
point = pCont.particlePosition
dist = sqrt ((point.x * point.x) + (point.y * point.y))
dist = sqrt ((dist * dist) + (point.z * point.z))
--adjust stray particles
if dist > 50 then
if point.x > 0 then
pCont.particlePosition.x = pCont.particlePosition.x - .25
else
pCont.particlePosition.x = pCont.particlePosition.x + .25
if point.y > 0 then
pCont.particlePosition.y = pCont.particlePosition.y - .25
else
pCont.particlePosition.y = pCont.particlePosition.y + .25
if point.z > 0 then
pCont.particlePosition.z = pCont.particlePosition.z - .25
else
pCont.particlePosition.z = pCont.particlePosition.z + .25
--set target position
sel = execute("$conn_target_" + pCont.particleInteger as string + ".pos")
--find vector of separation
vect = sel - pCont.particlePosition
--set target finding
pCont.particleSpeed = vect / 1000
--success test, is particle considerably close to target?
if ((vect.x > -4) and (vect.x < 4)) and ((vect.y > -4) and (vect.y < 4)) and ((vect.z > -4) and (vect.z < 4)) then
--choose new target at random
old = pCont.particleInteger
do
num = random 0 23
if not (old == num) then
new = true
while new = false
pCont.particleInteger = num
--store position
pos = pCont.particlePosition
--spawn new on success
pCont.AddParticle()
pCont.particleIndex = pCont.NumParticles()
pCont.particlePosition = pos
do
num = random 0 23
new = true
while new = false
on Release pCont do
Doctor?
Unread 15-02-2004, 13:36
Re: Cybersonics 103 Animation Teaser...
*scratches head* what?
Unread 15-02-2004, 16:25
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
HOLY WOW THAT'S AWESOME.
... but what does it do...? lol
Unread 15-02-2004, 17:15
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
So.... why use maxscript when you could do most of this with Particle Flow system? Or am i missing something?
Unread 15-02-2004, 17:41
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
on Init pCont do
--random targets
on Proceed pCont do
if dist > 50 then
if point.x > 0 then
else
if point.y > 0 then
else
if point.z > 0 then
else
do
num = random 0 23
new = true
while new = false
--store position
pCont.AddParticle()
do
num = random 0 23
new = true
while new = false
on Release pCont do
What the...?
Unread 15-02-2004, 21:50
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Whatever it is, I bet it's awesome...
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 15-02-2004, 23:57
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
i agree with Lev, what is the special secret? Or are you just trying out the max script?
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 16-02-2004, 22:31
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
MAXscript allows for recurring transformations to occur when you want them to (like when an object nears a target). There are just some things that are really inefficient using the graphical system. That is the nature of a GUI.
This is just an ambigous way of posting the main focus of our storyline without giving it away yet. Hope everyone is doing well and on track for the fast approaching deadline.
Doctor?
Unread 16-02-2004, 22:36
av11d's Avatar
College Bum
Hey! Don't bash the GUI :-P
I liked your animation a lot last year and this year it looks like it will be awesome again. Deadlines... oh boy.
Team 75 is attending both the PA and NJ regionals, so I'll see you there! Later.
Unread 16-02-2004, 23:10
Lev's Avatar
Lev Lev is offline
Particle Flow system allows you to have complex procedural behaviors, including finding target and checking for distance - all through GUI
Unread 16-02-2004, 23:15
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
Make a scene. Have particles chase a target. Once successful, have them chase another target at random in the scene. Do that without a script and with one event. I want to know how!
Doctor?
Unread 17-02-2004, 00:10
Lev's Avatar
Lev Lev is offline
I would, but right now im too busy with our animation. I'm not sure what exactly you mean by "one event", but YES, i can make such scene with a single particle system, controlled from one place. Particle Flow is the best addition in 3dsmax6, after mental ray.
Unread 18-02-2004, 14:05
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
It depends how you set it up in the event manager as to how well it would work, but i bet if you do it right it would work within the GUI, but scripting seems easier then taking the time and testing them out. Good job with the script, did you do it through tutorial??? or was it all purely thought up with a bit of inspiration????
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 18-02-2004, 14:40
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
No tutorial. Just the reference file and the index.
Doctor?
Unread 18-02-2004, 20:25
Lev's Avatar
Lev Lev is offline
Just finished the scene. Took about 3 minutes to set up, and 5 to tune the settings. no scripting, one particle system.
Here is the scene file: http://web.mit.edu/~levpopov/Public/...rticleflow.max
Here is the rendered sequence (30sec - 11mb, sorry): http://web.mit.edu/~levpopov/Public/...rticleflow.avi
Particle Flow systems are awesome.
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
Image Discuss: Team 108 Animation Teaser CD47-Bot Extra Discussion 4 14-03-2003 13:22
Cybersonics Team 103 Animation Complete reisser 3D Animation and Competition 17 02-03-2003 16:10
2002 Animation Software Jay Lundy 3D Animation and Competition 34 26-02-2002 20:40
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
