Re: Bosch Drill Motor Clutch Spring Dimensions??
bump
I spent a good 10 minutes looking for this yesterday, but I ask, why not take the dimensions yourself? I would, but our robot it finished and shipped already.
I assume that you would make a solid peice in order to prevent the clutch from slipping. If this is the case, then PM me and i will send you instructions on how to weld the clutch and remove the whole spring assembly.
| Bosch Drill Motor | rmmlg | Inventor | 7 | 17-12-2003 14:33 |
| White Paper Discuss: Locking the Bosch 3360 Drill in low gear | CD47-Bot | Extra Discussion | 4 | 05-08-2003 02:10 |
| Replacement Bosch drill motor assembly | james700 | Motors | 3 | 31-01-2003 21:08 |
| BOSCH Drill Transmission Assembly | archiver | 2001 | 2 | 23-06-2002 22:08 |
| Bosch Drill Motor CAD Files | Madison | Inventor | 10 | 09-12-2001 00:14 |
