Go to Post Man, what's the point of teaser videos if nobody looks closely at them. - Knufire [more]
Unread 15-02-2004, 19:16
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 1067 electronics
Unread 15-02-2004, 19:18
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: pic: 1067 electronics
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
Now since only 2; 40 amp breakers are in use, what combination of the 2 drill motors and 2 cim motors are you using???
-Michael Dessingue
Unread 15-02-2004, 20:54
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
it looks great... just make sure you can get to your program and tether ports! man i wish i had that much room to lay the electronics out! keep up the good work
"You're not a real programmer until all your sentences end with semicolons;"
Unread 15-02-2004, 21:01
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I really don't see how you can get the programming/tether cables into the controller with those cables going to the speed controllers there (granted it may jsut be a bad angle). Also on the main breaker, it doesn't look like you'll have an easy time getting to the reset switch, which FIRST officials always makes a big deal about.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 15-02-2004, 22:26
Noah Melamed's Avatar
Noah Melamed Noah Melamed is offline
FRC #0637 (Mr. T)
FTC #0030 (Mr. T)
Noah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura about
Send a message via AIM to Noah Melamed
I also noticed that your HI-AMP breaker switch is covered. Thats against the rules. It was my understanding that the breaker needed to be uncovered and easily accesible. Im also not posotive but your modification of the MAXI fuse block may also be considered tampering with a component and be against the rules
Unread 15-02-2004, 22:40
First stated to save weight, you may remove some of the fuse panels on the maxi panel breaker, they each connect by 2 or 4 screws on the bottom side. At competition, you should always have your removed panels for replacment.
-Michael Dessingue
Unread 17-02-2004, 21:25
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Those (copper? Brass?) things in the fues block are HEAVY!
If you seeo ur other pics, you will notice that we are using 2x drill and 0x CIM this year, and so we took them out. We also found out that running the black wires through the empty slots in the fuseblock was the most elegant and shortest way to do it . . . a win-win, especially since its legal.
About those program/tether ports: the wires are near enough the board that we can get to them, and they are on the side which makes access really really easy.
About the switch: I don't know why there isn't a hole over it now. There will be soon.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 18-02-2004, 12:40
ESchneider's Avatar
ESchneider ESchneider is offline
Eric "Schroder" Schneider
#1018 (Pike Robodevils)
Team Role: Student
ESchneider is an unknown quantity at this point
That looks a little like ours. We have a very small space to fit all our electronics. Me and our electronics team were able to design a three level tower for all the electronics and robot controller. We have maybe a cubic foot of space for the compressor, battery, tanks, etc.
Get Your philosophy from a bumper sticker-Billie Joe Armstrong(Green Day)
Team #1018 Pike Robodevils www.robodevils.com
Unread 18-02-2004, 16:12
AKA: theshadow
FRC #0620 (WarBots)
Cool Re: pic: 1067 electronics
Our electronics looks similar ( we didnt do as neat of a job with the holes ) but its in 3 layers. RC, powerblock, and main breaker on top, then 5 victors, our ground stud** and the big brass 40 amp fuse block on the second layer, and the third layer has 4 spikes, the main fuse block, and the 7.2 volt battery. the whole thing is like 12x10x11", which is less then a sqare foot. however the battery and compresser got delegated to the chasies team, so there not my problem .
**ground stud. when i say ground stud, i meen a piece of angle aluminum that i drilled a bunch of holes in. is the "ground stud" an essental piece? it would be a pain to redo it now, and i see no added electrical benifit. actualy the system i have now can deffenetly carry the current.
Unread 18-02-2004, 17:19
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
While I can't get the wiring diagram to load to verify my statement, you are only allowed to wire the robot as shown in the wiring diagram. Given that the ground stud is in the wiring diagram, you do have to use the one that is provided. I doubt that your custom ground stud would pass inspection. While it may be a pain to change it, you probably need to be safe.
Matt
Unread 18-02-2004, 19:07
#1067 (SLUH)
Matt
Yeah, you definatly can't use just angle bracket for your ground stud.
Besides, aluminum isn't a great conductor, you are introducing extra resistance into your system that *could* cause problems.
I was under the impression that you weren't allowed to do that much tampering (let alone substitution) in your control setup.
pic: our super nicely organized electronics.. CD47-Bot Robot Showcase 4 18-02-2004 16:13
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
