Go to Post After all FIRST & CD are both places to learn everything. - popnbrown [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 18-02-2004, 17:24
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: CSS Based Design
Originally Posted by jonathan lall
I found a really good implementation of just about everything mentioned in this article here!
such a shameless plug... I like it. can't say our website is very good, but then again I'm not the one doing it.
a little sidenote... if you're gonna put a link to the w3c validator on your site... maybe you should have your site validate as correct.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 18-02-2004, 17:28
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I just wrote in the offending feature (the CD47 Spotlight feed) about five minutes ago, that's why it's not validating... thanks though, I see the problem.
Unread 18-02-2004, 17:37
Computer Guy
AKA: Dav
yeah, that's the only thing I don't like about external content - most of the time it's not standards compliant (although in this case you can probably just reinterpret it to have it match the standard)
Unread 19-03-2004, 00:38
jhnphm jhnphm is offline
jhnphm is an unknown quantity at this point
I just read the W3C docs, and google for anything I don't understand. For Javascript I look at www.quirksmode.org and devedge.netscape.com.
Our website is done in PHP and XHTML, with some perl to generate the static gallery thumbnails, and a pure CSS layout. The server sends the content xhtml+xml for everything other than IE to remain standards compliant (also, if there's a syntax error anywhere, the entire website breaks, which helps keep standards compliance). I plan to add a style switcher soon, but feeling lazy now. We are also using mod_rewrites to hide the ugly PHP URLs for aesthetic purposes (also makes it slightly more difficult to pass potentially malicious parameters, though we also check for those in the scripts).
www.broken-llama.com/robotics
Unread 19-03-2004, 01:13
Good call serving proper MIMEs only to proper browsers; I did the same with an ultra-simple script. Glad to see other people are too. I also have a style-switcher, which I also wrote myself but derived "inspiration" from the aformentioned A List Apart. As for mod_rewrites, I never did take the time to learn them. I started reading about mod_rewrite a while back and there was so much that I was overwhelmed and just forgot about it--simple stuff is easy, but what I want to do isn't. Anybody know of anywhere with a concise paper on mod_rewrite?
Unread 20-03-2004, 00:00
This guide assumes knowledge of regular expressions.
IThe mod_rewrites on my local copy of the site (out of date by two months, and I stripped out redundant statements that weren't needed because of the usage of the <base> element) and commented are:
 #Syntax is "RewriteRule [URL RegExp] [Replacement with optional back references [[Flags]]"
 RewriteRule ^/$ /robotics/ [R,L]
 #Redirects http://localhost/ to http://localhost/robotics
 #R flag redirects, L prevents fall through to statements below
 RewriteRule ^/robotics/pages/(.+)$ /robotics/index.php?file=pages/$1.inc [L]
#Using W3 recommended URIs, which makes it more difficult to rewrite URIs, since there is the problem of what to rewrite to. This has been solved by dumping all pages under the /robotics/pages directory, and use the <base> element to shift the initial path for relative URIs to just /robotics/ . All the "pages" are files with the .inc extension which are included into PHP. The scripts filter for the .inc extension for security purposes.
Unread 25-03-2004, 22:03
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
My rewrite file looks like the following...
RewriteEngine On
RewriteRule ^images(.*)$ images$1 [S=1]
RewriteRule ^(.*)/$      ?path=$1 [L,NS,QSA]
Just so you know, this rewrites EVERYTHING. The rewrite rule for images marks the image folder as being directed to that folder (and then skipping the following rule, so it doesn't run into the other rewrite). This way everything is passed into your CMS and it can handle everything for you.
I then wrote a custom CMS solution for the site that could then parse $_GET['path'] and return the appropriate page...
rawr
Unread 29-03-2004, 01:20
Just added a style switcher at the bottom of our page. 188 has a nice website. In retrospect our website's navigation is rather bad.
Unread 08-04-2004, 22:03
RyanIdium RyanIdium is offline
RyanIdium is an unknown quantity at this point
try http://www.w3schools.com/css/default.asp .
Unread 07-05-2004, 19:46
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Brandon,
That's a great list. Lots of good info there. If I may, I have two to add...
#1 The Zen Garden . This really awakened me to to POWER of CSS. Click on the designs on the right side of the page, They will load up different CSS files using the same html file. Really cool.
#2 Webmaster World . This is a News and Discussion for the Independent Web Professional site. It is a great community forum like Chiefdelphi dedicated to web issues. It's free to register for the public side. There are forums dedicated to all web subjects including a terrific CSS forum. Post a question and someone will toss out an answer. There is a non-public side, that deals with the business side of the web that makes really interesting reading. It's good community, very much like we have here.
jb
Design Sharing Rod General Forum 32 14-01-2004 22:00
Roller Chain Based Three Speed Transmission Madison Technical Discussion 11 09-01-2004 16:40
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
