Go to Post The next hint will be game hint #3. Everyone will go crazy trying to figure out which of the fake hints was hint #2. - Joe Ross [more]
Unread 18-02-2004, 19:51
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: Victor problems
Originally Posted by WCS V
Have you checked the pwm signals going into the victors? If the lights on the victors are not solid orange, there is probably a problem with the pwm inputs.
I second that. A flashing light on the Vicky means its not getting a signal.
Check your PWM connections
If they are fine, take a multimeter and test the cable (we had a couple bad ones this year. And the cable we incenerated, but thats another story)
Then check programming.
If all that checks out, use a new PWM cable, don't so it neatly, just connect it. All of our PWM's are ziptied and run behind the board, its hard to keep them straight. We have had some problems putting them in the right place.
Also, you guys probably have done this a hundred times, but make sure your PWM cables aren't in backwards anywhere. Double and triple check everything.
Heh, careful when using a three-end PWM cable (you know, that can control 2 spikes or something). Our programmer was working, using one of those (because it is, well, was a spare). Anyway, the unused end fell into a Vicky. About two feet of insulation on the cable burned instantly. Large cloud of white (and probably carcinogenic) smoke. Thankfully, the victor is fine.
Enough story. Run the checklist, see if it works.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
