Go to Post Michigan is all about tough love. If you can make it there you can make it anywhere. - Koko Ed [more]
Unread 18-02-2004, 22:11
KWalsh KWalsh is offline
KWalsh is an unknown quantity at this point
Pneumatics Programming
Hi,
Can someone tell me how to go about programming multiple pneumatics? And how to assign them buttons on the joystick? Newb question brought to you by Team 1191, if someone could help it would be greatly appreciated, thanks
Unread 18-02-2004, 22:15
Re: Pneumatics Programming
what do you want them to do? usually you program each solonoide to trigger on a different joysitck button, or switch on a custom control box.
Unread 18-02-2004, 22:21
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
We're doing a multi-pos. system, but yes, same thing.
Unread 18-02-2004, 22:32
have you seen the thread on multipositioning with pneumatics? I think most of the details were covered there.
Unread 18-02-2004, 22:46
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Check the White Papers section also, in the Technical group.
There is a sketch of a layout circuit -
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-02-2004, 23:04
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
We programmed our last year to extend when we held one button. Makes it both extend and turns the other solenoid on. And stop when we let go. Retract was the same, just on a different button. As for programming specifics I can't answer anything.
Unread 19-02-2004, 07:36
AKA: Jamie Bliss
Yes, That is simlest.
Our idea was using a pot for 'Target' position and using a sensor with 2 solenoids to make it stop.
Like:
Const Arm_Upper_Stop as Unsigned Int = 150
const Arm Upper_Catch as unsigned int = 140
Const Arm_Upper_Range as Unsigned Int = 130
Const Arm_Target as Unsigned Int = 125
Const Arm_Lower_Range as Unsigned Int = 120
const Arm_Lower_Catch as Unsigned Int = 110
Const Arm_Lower_Stop as Unsigned Int = 100
void inter_ArmSensor(void)
 Static iPrevValue as unsigned int
 //Continue after catchup
 if (iPrevValue >= Arm_Upper_Stop & ArmSensor < Arm_Upper_Catch)
  {ArmMotor_Go;}
 if (iPrevValue <= Arm_Lower_Stop & ArmSensor > Arm_Lower_Catch)
  {ArmMotor_Go;}
 //Emergancy Stops
 if (ArmSensor >= Arm_Upper_Stop)
  {ArmMotor_Stop;}
 if (ArmSensor <= Arm_Lower_Stop)
  {ArmMotor_Stop:}
 //Start Cylinder
 if (ArmSensor >= Arm_Upper_Range)
  {ArmCylinder_Out;}
 if (ArmSensor <= Arm_Lower_Range)
  {ArmCylinder_In;}
 //Stop Cylinder
 if (ArmSensor < Arm_Upper_Range)
  {ArmCylinder_Stop;}
 if (ArmSensor > Arm_Lower_Range)
  {ArmCylinder_Stop;}
But I have a more efficient idea.
Unread 19-02-2004, 08:46
AKA: Nelson Green
You could use one of the magnectic sensor actuators from bimba and control the cyclinder based on the position of the piston throw. That would be simple and super efficient. I don't know how much more these cyclinders weigh but I doubt it could be much.
Unread 19-02-2004, 09:17
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Like:
  {ArmMotor_Go;}
  {ArmMotor_Go;}
 //Emergancy Stops
  {ArmMotor_Stop;}
  {ArmMotor_Stop:}
 //Start Cylinder
  {ArmCylinder_Out;}
  {ArmCylinder_In;}
 //Stop Cylinder
  {ArmCylinder_Stop;}
  {ArmCylinder_Stop;}
If anyone uses that make sure to change the Consts to lowercase. (Horrible error, Astronouth. )
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
programming the compressor archiver 2001 4 23-06-2002 23:19
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
