Re: Drill Motor + Gearbox + Breaker Problems
This is just a list of things I would check:
Are the 40 amp breakers are tripping?
Is the clutch in the drill motor locked into high or low gear?
Is possibly gears slipping and not making contact?
Are the drills set to the same gear on both sides (ie.. high/high or low/low)?
Is cooling efficient? Are the drill motors over heating at all? They tend to like to do that.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
