Go to Post More to the point, stop worrying about whether your "Atlanta bot" got screwed over or whatever. Worry about whether you've got an "Atlanta team." - RebelWithARobot [more]
Unread 18-02-2004, 14:42
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Stuypulse team 694's Bot
Unread 18-02-2004, 14:43
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: pic: Stuypulse team 694's Bot
Here it is. Basically finished and in full competition condition(the picture is from about 3 hours before it was completely finished). The robot works like a charm. We've got pvc wings on pneumatics on the outside, at the great 6 inch height. We have the kit wheels on right now which allow us to drive up the side and manuever around the raised areas easily. We have a second set with our own special rubber to be put on. The drivetrain has two speeds controlled by a servo on the bosch gearbox, light simple and it works as long as you're not moving. We've got an arm, the bottom joint has two positions controlled by a pneumatic and the top joint has full rotational ability. The ball grabber has large 20 inch hoops which completely encompas the ball and lock it in. We can place the ball on the tall and short goals. We've got a goal grabber on the back of the robot. Its a drive on mechanism. We can just drive back onto a goal to grab it. To release it we have a pneumatic. The tube along the arm is our extender. The one in the picture isn't completely up to date, but it extends to well over 10 feet and is guided by the arm so we can grab from many locations and do it easily. So that about covers it, we do everything except grab the 10 point ball or store little balls. I'll get some pictures of it in action up today. Plus you can see more at http://stuypulse.com
~Ian
Team Website
Unread 18-02-2004, 14:47
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
nice looking robot, i just have a question, have you had any problems with that long chain snagging or dismounting the sprocket while you are manipulating your arm?
-Michael Dessingue
Unread 18-02-2004, 14:55
MASherry MASherry is offline
Team Role: Driver
MASherry has a little shameless behaviour in the past
nice bot! just wondering what type of stering you guys were using, b/c our team is using tank turning and we ran into a problem with the pneumatic wheels gripping too much. How did u solve that problem? Can u guys hang?
Unread 18-02-2004, 15:06
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
Increasing the pressure in the tires reduces the contact patch, so you can reduce traction that way. That should help turning somewhat, without a whole redesign. Hmm, Hummer-style tire inflation, anyone? :-)
Unread 18-02-2004, 22:28
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
We do have a turning problem. An hour more of work and we will have replaced the kit wheels with our own custom wheels. We covered the wheels in velcro and then have sets of treads which velcro on. The one we'll probably use has a very low side to side coefficient of friction and a very high forward back coefficient of friction plus his ridges to help climb steps and lips easier. So we are sorta of doing a whole redesign.
The poor traction of the kit wheels were something we took into account when we decided what to make. They're designed for wheechairs which usually have two casters. The result is that they have a very high side to side friction(just look at the tread). Its going to be a big problem for first teams this years. You can cover one set(forward or back) in a slippery substance and it should allow you to turn, but you'll lose the traction those wheels provide which could cause a problem going up the lip.
As for hanging, we can hang the robot pulled itself off the ground to weigh itself today. We do have a bad habit of breaking a piece of our extender turned out the veclro that the hook sticks to the tip of the extender with was stronger than the extender's wood. So we're hardening that up so we don't have to replace it every match.
~Ian
Team Website
Unread 19-02-2004, 00:13
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Cool Design!
Do You guys plan on going for the 10pt. balls to release the 5pt'ers or are you guys just gonna hang and mess with the 2x balls.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 19-02-2004, 00:18
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Very nice bot. I see a pneumatic system at the base of the tower. Is this to be able to have the tower go parallel to your bot and be able to herd balls?
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 19-02-2004, 01:00
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
The arm has positional control so we can set it to a position and it will stay there. This allows us to hit the ball on the stand. We've also got light sensors on the bottom so we can do it accuratly.
The pneumatic system at the base of the tower is to allow it to have 2 positions. We have one angled up and back a bit and another down at about 60 degrees. This allows us flexibility without the complexities of having to have the arm powered by a motor(which we did last year). The arm doesn't need to drop down since we have the wings which pop out the side and we need to protect our ball grabber.
~Ian
Team Website
Unread 19-02-2004, 01:49
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Ian,
Add a single solenoid to your exhaust of the solenoid for your tower tilt and you can have several positions instead of two.
Check out this thread to see how:
http://www.chiefdelphi.com/forums/sh...ad.php?t=23934
I think it would be helpful and it would only cost you a 1/4 lb of weight and some extra programming for control of the angle of your tower. This would be helpful both when climbing stairs and when manipulating the 2X ball. If you have any questions about multi-positioning just ask. We did this last year and it worked great.
Unread 19-02-2004, 02:18
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
I saw that and was thinking of adding it but the main idea of using the pneumatic instead of a motor was not for the weight but instead because we wanted to keep it simple. We don't need any more positions and so having them will only get in the way.
Presently we're programming the arm so that it will automatically go to positions such as to place the ball in a goal or pick one up off the ground. It does 90 degrees in about .3 seconds so having it under computer control should allow us to go much faster than human controlled teams.
We might work on the multipositional thing after competition but for now we really don't need it.
~Ian
Team Website
Unread 19-02-2004, 02:27
AKA: Nelson Green
The cool thing about it is that you don't have to use it. You can have a switch which will turn it off or allow you to use it or disabling it completely involve removing a piece of tubing. It's just an idea if you ever need that mid position with the 2x ball. So I decided to throw it out there. If you want any help with it just ask. And you can make some very simple controls for it. Our system was you held one button to make it go out, and one to go in. If you let go of the button somewhere in the middle it would stop. But good luck whatever route you choose. It looks good.
Unread 19-02-2004, 12:30
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
I've posted a minute long video showing off some preliminarytesting of our robot you can find it here:
http://stuypulse.no-ip.com/ftproot/L...%201%20low.wmv
those of you who are apt might be able to find a medium quality video too
~Ian
Team Website
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
pic: Team 151's bot CD47-Bot Robot Showcase 7 06-03-2003 09:41
Novi Kickoff Seminar List (Tentative) Joe Johnson General Forum 1 05-12-2001 13:47
