Go to Post there is no such thing as too many offseason competitions. - Berserker [more]
Unread 19-02-2004, 01:08
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Legality of Spring Loaded Pistons
Originally Posted by KenWittlief
and you should be able to purchase an off the shelf spring loaded piston device, as long at its not a pneumatic cylinder from 'someone else'
Spring-loaded pistons are NOT legal. Review the fourth paragraph of <R54> and the parts-use flowchart (including the expanded flowchart in Rules Update #10) VERY carefully.
Is a spring-loaded piston an air cylinder ordered from the Custom Cylinder Order Form? No.
Is it a purchased cylinder or actuator IDENTICAL to those available on the Custom Cylinder Order Form? No.
Spring loaded pistons are not available on the order form in the pneumatics manual. Therefore, you cannot purchase pistons that are spring loaded.
-dave
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
