Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 19-02-2004, 06:19
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Getting the relays to stay constant
Right now we have our pump hooked up to one of the spikes on #5 and while it works (press a button and it goes on) it doesn't stay on and it's really annoying to have to hold it down.
I think* (i don't know how to code and no one on the team does) that all I have to do is something like this
when joystick button is depressed set a variable equal to one
then do an if statement, if variable equals 1 to set the relay to fwd, else if, set relay to neutral position i guess fwd and rev are equal to zero?
I don't know the proper syntax or way about doing this, but i think it would only be a 1 or 2 lines of code
could anyone tell me how to do it or write it out so I could just copy and paste it into our code? plzzzz
It's #5 if you want to write it out
Unread 19-02-2004, 06:50
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Getting the relays to stay constant
Do something like this:
unsigned char state = 0;
unsinged char switchState = 0;
// Check switches. Substitute switch for whatever switch on the OI you are using
// I use the switch state to prevent the switching of the state do to not realeasing the button right away
if(switch && !switchState)
    // Set switch state
    swtichState = 1;
    // Switch states
    if(switch)
        state = 0;
    else
        state = 1;
else if(!switch)
    // reset the switch state
    switchState = 0;
// Subitute relay with your relay
if(state)
     // Run forward
     relay_fwd = 1;
     relay_rev = 0;
else
    // Turn off relay
    relay_fwd = 0;
    relay_rev = 0;
Put that whole thing where ever you are doing your cheking currently. Put the varable declarations at the top of whatever function you have this in. That should work. (I hope... )
Unread 19-02-2004, 10:17
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
This isn't what you're looking for, but you may like this, use it, and even learn from it. In the default code, if you hook up the compressor to relay 8, and hook up your preassure switch( that came with your kit ) to digital in 18, whenever the preasure is below 95, it will pump untill it gets to 115 (or somewhere around there). What happens is this:
relay8rev = !digitalinput18;
those names area ll wrong because I dont have code with me, but what it does is set the relay to the opposite value of the digital input sensor (in this case, the preasure switch). If the swith is 1 (it's up to preasure) the relay is off. If it's below presure (0), then the relay will fire up (to 1). Hope you can learn something from this.
~Bstempi
stay on the carpet????!!!! soap108 Rules/Strategy 12 13-03-2003 12:50
SPIKE relays Andy Brockway Electrical 2 13-11-2002 13:22
where are teams going to stay? archiver 2001 2 24-06-2002 02:49
How many hotels did you team stay at?? Elgin Clock Championship Event 4 10-05-2002 17:53
How do you control relays BinaryBob0001 Technical Discussion 2 21-01-2002 08:42
