Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 18-02-2004, 22:57
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
Question Inconsistant Joystick
Here's my problem:
I have an arm that rotates, and inside of it, there is another arm that pokes out. What I wanted to do was use the second joystick to control it. I use p2_y to control the rotation of the arm on pwm04. I use the hat on p2 (p2_wheel) to retract/extend the arm by pressing up or down. In defaultroutine, pwm04 = p2_y. For some reason, the hat will work. It will tell the arm to do what I want it to. The kick in the but comes here: when using dashboard, it tells me that pwm04 is always 127. Sometimes it works, and sometimes it doesn't. It doens't matter what joystick I use, it just randomly decides to work. Anyone else experience this? Should I invest in a new controler? Many thanks.
~Brian Stempin
Captain, Team 708
Unread 18-02-2004, 23:03
Re: Inconsistant Joystick
is the command sending Pwm4 out to the dashboard before the command that sets it to the joystick value?
search on pwm4 in your code and make sure its not getting equated to something twice.
Unread 19-02-2004, 07:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Are you using basicly the default code? Or did you rewrite the Default_Routine? Check below the pwm assignments, and comment out the stuff with pwm04. I had the same problem, and that fixed it. I think its limit switches, but I can't remember.
Unread 19-02-2004, 09:50
Captain
Team Role: Student
Lightbulb Re: Inconsistant Joystick
Truth, when I did that, it worked. That was the only time it worked. After that, it went back to behaving as before, but I'll be sure to double check it. It's possible that someone changed the code without my knowing. Other than the limit switch default stuff, pwm04 isn't used anywhere else. Just out of curiosity, should the limit switch stuff matter? I browsed through it and haven't taken the time to pick it apart, but I thought the default was set so that a certain set of pwms didn't operate is a digital input was set to 1. Thank you both for your input.
~Bstempi
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
