Go to Post Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. - Andrew Schreiber [more]
Unread 17-02-2004, 11:37
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
Programming Help
Hey,
We need to look at a sample piece of the main part of somebodys arm code thanks! We are using C Programming and we need just an idea on how we are gonna program it thanks
-chris
Unread 17-02-2004, 12:10
Re: Programming Help
it all depends on what you want to do..
1) What pwm output will it be on
2)Do you want it to include special functions (such as a trigger to make it go to a certain point)
These are easily modifiable in the given default code.. just goto user_routines.c in the workspace, then find where it shows the mappings of inputs (joysticks) to outputs (pwm outouts, controlling motors)
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
What do you want your arm to do? How is it wired up? Do you have any sensors doing anything? I'll post some sample code later, but the chances that it will be right for your arm are slim...
Unread 17-02-2004, 12:56
the only thing the arm does that excludes the grippers is move 270 degrees. And we are using the van door motor!
Unread 17-02-2004, 13:00
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
then you are going to want to control the motor using a Victor, and thus a PWM. set the variable pwmXX (XX being the number of the output the victor is connected to) to a number from 0 to 255 - 0 is full reverse, 255 is full forward, and 127 is neutral (stopped).
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 17-02-2004, 13:13
If you want it to move exactly 270 degrees, you will need some sort of feedback system. I would recommend a pot - do you know how to wire one up?
Unread 17-02-2004, 13:52
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
You need to read the 2004 Programming Reference guide located here:
http://www.innovationfirst.com/FIRST...10-29-2003.pdf
You also need to read the 2004 FRC Default Code Reference Guide:
http://www.innovationfirst.com/FIRST...e_2004-1-7.pdf
The second PDF document explains in detail what's going on in the default code that Innovation First provides.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 17-02-2004, 14:00
heres a very helpful power point presentation by the people at Innovation First http://www.usfirst.org/robotics/C_help.htm
Unread 17-02-2004, 15:15
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
This may be oversimplified, but all you have to do is use a PWM output as a function of a joystick input. something like pwm(#)=p2_y; (or whatever port your joystick is in). U can even use the Limit_Mix function so that it reads pwm(#)=Limit_Mix(2000+p2_y);
edit: Actually if you are using a joystick, all you have to do is plug it into port2 on the OI, and ur speed controller for the globe into PWM OUT 2 and you are set to go. The y-axis controls the arm. (Default code can do wonders lol)
Unread 19-02-2004, 11:57
shsdragon shsdragon is offline
shsdragon is on a distinguished road
Send a message via AIM to shsdragon Send a message via Yahoo to shsdragon
static long timeCounter = 0; //this will count the number of 26.2ms ticks that have passed
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
if(timeCounter <= 115) //3 seconds / 26.2ms = 114.5
pwm13 = pwm15 = 30;
else if(timeCounter <= 134) //we'll give the relays about .5 seconds to switch
pwm13 = pwm15 = 0;
relay1_fwd = relay2_fwd = 1;
else
//put stuff to do after the other things here
//you can also add more else-if statements to time other things
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
timeCounter++; //add one to the tick count
this should work fine - hope it helps!
mmy motoors don't move
[/font][color=Red]Jearvon Dharrie
Unread 19-02-2004, 12:11
Computer Guy
AKA: Dav
pwm13 = pwm15 = 30;
pwm13 = pwm15 = 0;
else
shs, i already sent you a PM answering that question that you PMed me before you posted it here - check your PMs. but in the name of simplicity...
you need to add a call to Generate_Pwms() after the Putdata() line, like this:
void User_Autonomous_Code(void)
             pwm13 = pwm15 = 30;
             pwm13 = pwm15 = 0;
        else
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
