Re: Legality of controlling 2 cylinders with 1 solenoid
As long as the regualted pressure isn't above 60psi, I'd say it's well within the rules. |
We used this last year. As long as the regulator is set at 60 psi, it is legal.
Just a word of cuation if it werd: if you are using the setup, make sure that the tubes are the SAME LENGTH, so the same ammount of airflow goes into each cylinder at the same time and rate. |
The good news is that the cylinders will end up exactly where they should be in end end anyways. |
you can hook up as many cylinders as you want to a solonoid
| using single solenoid like a double | SteveO | Programming | 14 | 02-02-2004 22:51 |
| Custom pneumatic cylinders | duckshepherd | Pneumatics | 7 | 24-01-2004 20:39 |
| multiple cyclinders from one double solenoid | Ed Crammond | Pneumatics | 1 | 07-02-2003 18:49 |
| Beatty and Kingman | JAlpert | Regional Competitions | 51 | 08-04-2002 16:59 |
