Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Unread 19-02-2004, 17:22
quickie25's Avatar
quickie25 quickie25 is offline
quickie25 is an unknown quantity at this point
Is default code already loaded?
Hello all,
We are ready to begin testing but we cannot download the default code into our controller because our sys admin is gone for the day and we cannot access our com ports. Is the default code already loaded in the controller or do we have to download it to the controller to begin?
thanks,
team 1380
alloy - a mixture containing two or more elements fused together...(ie. A Team)
Unread 19-02-2004, 17:25
Re: Is default code already loaded?
there is default code already in the controller, but its not the latests version
Im pretty sure the one joystick drive that outputs on pwms 13-16 is not in all the RC units -
so yes, there is something in there
but if you are planning to drive with one joystick you might have to get the most recent default code from innovationfirst website and download it.
Unread 19-02-2004, 17:40
quickie25's Avatar
We are just trying to test 1 cim with the joystick using PWM 1? Should we have a problem doing that? We have tested a servo and that works fine, but when we hook up the speed controller (and its working fine) and the cim we dont get any output from the cim with the joystick. Any suggestions?
Thanks,
Team 1380
Unread 19-02-2004, 17:51
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Thanks,
Team 1380
Hmm.. Does the LED on the victor change colors as you move the joystick?
Unread 19-02-2004, 17:52
it should work - does the LED on the victor stay steady yellow with the joystick centered, and go green on full fwd and red on full rev?
do you have the victor powered through a 30 or 40 Amp breaker?
are you sure you got the victor hooked up with power on the right side? ( the same side as the pwm cable is on?)
if the LED on the victor blinks yellow it means its pwm cable is not plugged in straight, or pushed down all the way, or the cable is backwards at one end or the other
Unread 19-02-2004, 18:23
quickie25's Avatar
It stays yellow throughout and does not change colors
We have evcerything else correct, we are hooked up through 30a breakers, the victors are hooked up right, but the light stays orange throughout.
What does this problem point to? Is it a calibration prob? Could someone walk us through the calibration process?
Thanks in advance,
team 1380
Unread 19-02-2004, 19:06
quickie25's Avatar
Unread 19-02-2004, 19:42
if you connect a servo to the same pwm output, and the servo moves when you move the joystick, but the victor stays on solid yellow when you connect and move the joystick, then I suspect your victor is not working correctly.
The calibration process: get the official Victor Calibration Instrument (also know as a straightened paper clip :c) and push the little tiny button on the base of the victor and hold it - the LED will start to blink.
Move the joystick all the way forward, then all the way rev, then back to center - holding the tiny button the whole time, then release the button
the light should go back to steady yellow in a few seconds.
I dont think this will fix your problem, but you can try it - I recommend you try another victor - connect it up carefully, and see if it works.
Unread 19-02-2004, 22:51
quickie25's Avatar
As it turns out the problem was twofold:
1. All of our wires werent completely connected in their terminals
2. The victor wasnt calibrated together with the joystick trim
We are running now...
Thanks again for all of your help.
Team 1380
Modifying Default code great_one411 Programming 7 16-02-2004 10:32
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
