Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 19-02-2004, 17:56
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: Legality of controlling 2 cylinders with 1 solenoid
We used this last year. As long as the regulator is set at 60 psi, it is legal.
Just a word of cuation if it werd: if you are using the setup, make sure that the tubes are the SAME LENGTH, so the same ammount of airflow goes into each cylinder at the same time and rate.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 19-02-2004, 21:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I can categorically say that no matter how careful you are about tube lengths and such, you will never get the pistons to actuate at exactly the same time. You'll probably get it close in most cases, but air is like water. It follows the path of least resistance. One of your cylinders is going to have less resistance, friction, etc and it's going to actuate faster. Or if one of your cylinders is beeing blocked by something, it won't push against the offending object until the second cylinder is full.
The good news is that the cylinders will end up exactly where they should be in end end anyways.
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Beatty and Kingman JAlpert Regional Competitions 51 08-04-2002 16:59
