Go to Post just watch out for the evil, robot devouring ghosts - Mr. Pockets [more]
Unread 19-02-2004, 17:39
mtangolics mtangolics is offline
AKA: Mike Tangolics
#1403 (Cougar Robotics)
mtangolics is an unknown quantity at this point
Send a message via AIM to mtangolics
Legality of controlling 2 cylinders with 1 solenoid
I've looked all over the rules, the Q&A system and this forum, but I haven't been able to find anything about controlling 2 cylinders with one solenoid valve. Does anyone know if this is legal or not?
2004 Mid-Atlantic Rookie All-Stars
2004 Mid-Atlantic Highest Rookie Seed
2004 Chesapeake Xerox Creativity Award
"Robizzle Fo Shizzle"
Unread 19-02-2004, 17:51
sear_yoda sear_yoda is offline
Kid With The Credit Card
None #1189 (Breaking Pointe)
sear_yoda will become famous soon enoughsear_yoda will become famous soon enough
Send a message via ICQ to sear_yoda Send a message via AIM to sear_yoda Send a message via Yahoo to sear_yoda
Re: Legality of controlling 2 cylinders with 1 solenoid
I couldn't see why it wouldn't be. We've got this setup you're talking about for our herding arms, using two Y connectors.
As long as the regualted pressure isn't above 60psi, I'd say it's well within the rules.
throw away your microwave and eat cold food.
Unread 19-02-2004, 17:56
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
We used this last year. As long as the regulator is set at 60 psi, it is legal.
Just a word of cuation if it werd: if you are using the setup, make sure that the tubes are the SAME LENGTH, so the same ammount of airflow goes into each cylinder at the same time and rate.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
you can hook up as many cylinders as you want to a solonoid
Unread 19-02-2004, 21:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I can categorically say that no matter how careful you are about tube lengths and such, you will never get the pistons to actuate at exactly the same time. You'll probably get it close in most cases, but air is like water. It follows the path of least resistance. One of your cylinders is going to have less resistance, friction, etc and it's going to actuate faster. Or if one of your cylinders is beeing blocked by something, it won't push against the offending object until the second cylinder is full.
The good news is that the cylinders will end up exactly where they should be in end end anyways.
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Beatty and Kingman JAlpert Regional Competitions 51 08-04-2002 16:59
