Go to Post But on the plus side, we can drive the robot with a DDR pad, which is crazy-stupid-cool. - Not2B [more]
Unread 19-02-2004, 10:17
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Muffin fans ..
We're a rookie team, almost at the end of the build, with our bot nearing competion. We havent touched the muffin fans that came with the kit (a 120mm fan is quite tempting to play with for a geek )
We're using the drills, and after running them for about 20min, nothing seems to get hot enough to worry about. No breakers have popped, no victors have smoked. Should we put the fans on over the electrical board and or motors? Or is this just a waste of time?
Thanks
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 19-02-2004, 12:09
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Muffin fans ..
The last 2 years we have done this our motors have gotten really hot. They might not seem to be hot now, but try running them for 2 min nonstop at full speed. Trust me, they will get hot. Put the fans over the drillmotors. The eletrical board doesnt need them cause nothing is putting out that much energy.
___________________________
If all else fails, use a bigger hammer.
Unread 19-02-2004, 18:24
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Muffin fans ..
This is the first year 93 will be using muffin fans, to keep the electronics cool (as they are pretty compact this year! ) As long as you can get a decent airflow inside your robot by the motors, I wouldn't worry too much about putting in the fans. Unless you really need them, they're just extra weight and another thing to worry about wiring up!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 19-02-2004, 19:08
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: Muffin fans ..
You could run the muffin fans over the motors between matches, or use canned air, or something to that effect, to cool down the motors, if you don't want to worry about wiring the muffin fans up or adding weight. You could even build a heatsinc.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 19-02-2004, 19:26
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: Muffin fans ..
If you're just running the drill motors, their not gonna get hot because their is no load or strain on them. In competition, a lot of strain is put on the motors, and they get extremely hot. Using muffin fans is a very good way to keep them cool throughout the match.
As for using canned air to cool the motors, this is not recommended by a number of people, including engineers on this very forum. The reason is because it can damage the brush housings inside the motor. My team did this last year before each match, and while it worked well for a few matches, we started seeing problems down the line, such as the motors cutting in and out. It's just not recommended to use.
http://www.lions.odu.edu/~averma/pow...ill/sld005.htm
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
HOT drill motors Rich Wong General Forum 4 29-01-2003 22:38
Drill motor change out question?? archiver 2001 9 23-06-2002 23:36
Hey Wrestling Fans Out There Mike Schroeder Chit-Chat 9 28-05-2002 09:58
For You "The Mole" Fans Out There... Joe Matt Chit-Chat 0 16-02-2002 22:26
