Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 19-02-2004, 20:51
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
code violation...need help
We are having a problem surrounding the downloading of the hex file onto our robot controller. We tried to even download the default code and it doesn't work when we plug in the radio transmitter (get error message with radio modem). Can you help us?
Unread 19-02-2004, 20:55
Re: code violation...need help
what gives you an error message?
you cant use the radio modem to download your code, if thats what you are trying to do - you need to use the serial cable
Unread 19-02-2004, 21:57
Vince lau's Avatar
FRC #4914
we downloaded the program with a serial cable, but when we plug in the radio we get a code violation
Unread 19-02-2004, 22:00
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Try hitting reset...Its might work. I'm not too great with the programming but we have to reset ours after every time we run it.
Unread 20-02-2004, 16:31
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Is the radio modem in the right port? On both ends.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
