Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 19-02-2004, 21:03
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
Exclamation Changing 1 joystick code to 2 (rookie team)
We are a rookie team and we have noobies working on the C code.
We see the code for 1 joystick drive i.e.
/*---------- 1 Joystick Drive ----------------------------------------------
* This code mixes the Y and X axis on Port 1 to allow one joystick drive.
* Joystick forward = Robot forward
* Joystick backward = Robot backward
* Joystick right = Robot rotates right
* Joystick left = Robot rotates left
* Connect the right drive motors to PWM13 and/or PWM14 on the RC.
* Connect the left drive motors to PWM15 and/or PWM16 on the RC.
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
etc....
This is a 4 motor robot and we need one joystick to control the left side and a second joystick to control the right side.
HELP US PLEASE!!!! WE HAVE NO IDEA WHAT WE ARE DOING!!!
Thanks,
A Rookie Team
Unread 19-02-2004, 21:10
Umm Errr...
Re: Changing 1 joystick code to 2 (rookie team)
etc....
Thanks,
A Rookie Team
Ok i can help you. Just tell me what ports your joysticks are connected to and what PWMs your motors are connected to, and i'll tell you what to change.
1139 Alumni
in the default code, the outputs are mapped to:
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
so you could simply use the Y cables and put the two right motors on pwm01 and the two left motors on pwm02
or edit the code above to put the same signal on two outputs - if you want your right motors on pwm1 and pwm2 and your left motors on 3 and 4, change it to
pwm01 = p1_y;
pwm02 = p1_y;
pwm03 = p2_y;
pwm04 = p2_y;
BTW - this code is in the file user_routines.c - after you edit it you have to pull down the menu and 'make' your code (let it compile)
PS- make a backup copy of your default code somewhere first :^)
Unread 19-02-2004, 21:12
Joel J's Avatar
Joel J Joel J is offline
do you..
etc....
Thanks,
A Rookie Team
pwm13 = pwm14 = p1_y;
  pwm15 = pwm16 = p2_y;
Now, the joystick going into Port 1 of the OI will control your left motors and the joystick into port 2 will control the right motors.. assuming of course that the left motors are plugged into pwm13 and pwm14, and the right motors are plugged into pwm15 and pwm16. That help you out any? Two joystick drive is usually just a direct output from the joystick to the PWMs.. its the one stick code that takes a bit of work.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 20-02-2004, 16:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
ps- It's faster to compile by hitting F10, it won't recompile what you didn't change.
Unread 20-02-2004, 17:00
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
This piece of code can be found already created in the default code in the user_routines.c file.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
A ? about NASA grants computhief263 General Forum 18 29-03-2004 13:35
Novi Kickoff Seminar List (Tentative) Joe Johnson General Forum 1 05-12-2001 13:47
