Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 19-02-2004, 21:15
Kristin326's Avatar
Kristin326 Kristin326 is offline
#0230 (Gaelhawks)
Team Role: Student
Kristin326 is an unknown quantity at this point
Send a message via AIM to Kristin326
Question pressure transducer
where can we purchase a texas instruments pressure transducer?
*~*"Stop burning bridges, drive off of them..."*~*
Unread 19-02-2004, 21:23
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: pressure transducer
not to sound dumb but, what exactly is a pressure transducer?
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 19-02-2004, 21:59
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Google search: Texas Instruments Pressure Transducer
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 19-02-2004, 22:06
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
If I'm reading the flow chart correctly and what a pressure transducer is used for, I would say it is not legal to be used.
No energy sources other then the battery may be used, and it is a custom pneumatic part not from this year or previous, so it is not legal by these standards either.
Unread 20-02-2004, 00:15
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
A pressure transducer is not an energy source. It's an analog pressure sensor that allows you to see exactly what the air pressure in your pneumatic system is - unlike the pressure switch, which just turns on or off based on a fixed setpoint, the transducer outputs a voltage that is ratiometric to the pressure of the system connected to it. They are indeed legal - in fact, you should have received one in the kit of parts. It's a little brass thing with one threaded end and one end that has three wires hanging out of it.
Unread 20-02-2004, 00:19
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
Oh I see, what I read about and understood about it was that it took pressure and converted it into an energy source/flow.
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
