Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Unread 19-02-2004, 21:26
bheller bheller is offline
AKA: Brandon Heller
#0931
bheller is on a distinguished road
Team 931 Omniwheels
Omniwheel Render
Omniwheel Picture
Click on the above links to both a render and actual picture of Team 931's new omniwheels. The outer plates were waterjetted and milled by a sponsor, but the rest was student-fabricated, including the shafts, hubs, spacers, and rollers. These wheels are a drop-in replacement for the 9" Skyway wheels. We used 60A durometer urethane for the rollers. It's extremely flexible stuff -a pain to machine but worth it due to the excellent traction. The weight of the robot actually deflects the profile of the rollers so much at the roller edges that the wheel profile very closely approximates a circle.
So we installed them on the robot the other day, and they worked _too_ well! Think about it - with an omniwheel you essentially have casters when the robot's turning. The rotational inertia causes the robot to keep spinning when you lay off the stick, just like casters, causing overshoot. We're pursuing a gyro (ADXRS series) to fix this. The robot turns MUCH faster now.
Many thanks go to the Technokats, whose Trick Wheel design inspired these wheels. At the end of the season, I'll post a White Paper on the design, with inventor files, .dxfs and bill of materials.
Whaddaya think?
Brandon Heller
Team 931 Mentor
Team 449 Alum
Last edited by bheller : 19-02-2004 at 21:28. Reason: added blurb about white paper
Unread 19-02-2004, 21:28
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: Team 931 Omniwheels
Wow, very very nice.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 19-02-2004, 21:34
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Very Nice Trick Wheels!
It's always nice to know that something you worked on and helped build inspired someone to create something of the same magnitude if not better.
Unread 19-02-2004, 22:09
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Heh, those look uber familiar... like two of ours from last year, offset and with weight reduction.
How large are they? Based on the actual picture, I can't tell.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 19-02-2004, 22:11
Winged Wonder's Avatar
Winged Wonder Winged Wonder is offline
Engineer disguised as a Physicist
AKA: Leslie Salas
FRC #0233 (The Pink Team)
Winged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond reputeWinged Wonder has a reputation beyond repute
Send a message via AIM to Winged Wonder Send a message via Yahoo to Winged Wonder
those are cool!
I GIVE FREE HUGS AT COMPETITIONS!! (just ask!) | Real Men Wear Bodypaint Pink! | Good Luck This Year!!
Embrace your inner dorkiness, because face it, life is too short to be cool.
Unread 19-02-2004, 23:42
AKA: Brandon Heller
#0931
The OD is 9", the hub diameter is 2", and each roller is 1" diameter x 1.5"L.
Weight is 2.7lbs vs ~2.4lbs for the Skyway Bead-lok, but could be brought down to about 1.7lbs by replacing Aluminum with Polycarbonate. It'd look like this. These wheels are BEEFY, but the pictures don't show it. The roller axle size was increased from the Technokats design.
I wasn't involved with FIRST last year and didn't see your robot. Do you have any pictures? I checked your team's website and didn't see any from 2003.
Unread 19-02-2004, 23:46
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Lol, that's the exact same dimensions of ours...
We used Lexan instead of Aluminum, but we did use 60A urethane just like you.
Here's the pic/thread: http://www.chiefdelphi.com/forums/sh...03+omniwhee l
Unread 19-02-2004, 23:56
AKA: Brandon Heller
#0931
I see. The main differences between our designs is that mine uses an external milled slot (like 45) for the axles, so that we can remove any wheel without taking the wheel apart, and has two rows of rollers.
I did most of the urethane work. If you set up a jig, you can cut very accurate rollers. The stuff is so flexible that the cutting edge of a drill bit tends not to bite in. The holes we drilled with a .1875 drill bit actually came out more like .16. That's a lot of stretch! Originally the plan was to CNC the urethane to an exact profile. Liquid Nitrogen can be used to chill urethane to the point that it acts like a much harder-durometer urethane. I was all set to use that, but then the urethane arrived and we realized it was so flexible that the weight of the robot would compress it to a nearly circular profile.
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
Shelf Life Of A Team Vin211 General Forum 21 07-01-2004 22:31
Info for starting a new team (again, I'm sure) archiver 2000 3 24-06-2002 00:24
What constitutes the "Best" team? archiver 1999 9 23-06-2002 22:16
why why why...? archiver 2001 34 23-06-2002 22:13
