Go to Post "git er done" but do it right. - CJO [more]
Unread 14-02-2004, 22:30
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Hanging from the bar:
I ran a search for hang, and bar, and found only irrelevant results, so I don't think this is a repost.
My problem: The rulebook says your bot has to be suspended from the bar at the end of the match for the 50 points or whatever.
What if we are suspended from the bar at the end of the match, but as soon as we loose power descend at 1"/second or so . .
Will this count for 50 if we are in the air at the end of the match but slowly descend to touching the floor?
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 14-02-2004, 22:33
David66's Avatar
David66 David66 is offline
YA TOAST!
AKA: David Butzin
FRC #0066 (The Flyers)
David66 has a spectacular aura aboutDavid66 has a spectacular aura aboutDavid66 has a spectacular aura about
Send a message via AIM to David66 Send a message via Yahoo to David66
Re: Hanging from the bar:
the FIRST q&a says that you should build your robot to hang indefinately bwecause it can not be touching the floor until after the judges scores are final...and according to them that will be a minimum of 30 seconds
Proud Alumni of Team 66
2005 Great Lakes Regional Champions with Team 67 (HOT) and Team 68 (Truck Town Thunder).
2005 West Michigan Regional Champions with team 107 (Holland Christian High School) and Team 93 (New Apple Corps)
2002 National Champions
Unread 14-02-2004, 22:41
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I believe it was stated more along these lines; objects are expected to come to rest after 10 seconds, but FIRST also stated that it is expected that robots stay there for scoring purposes for at least 30 seconds otherwise you might not get your 50. This is of course understandable.
Unread 15-02-2004, 03:55
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
As long as you are up during judging.. If it can stay off the ground for a minute you are definitely in the clear.45 second is probably good. What I was wondering is would it be legal to be touching at the end of time and settle up to non-touching in the time before judging. With in a couple seconds after using something like a series of springs.
Unread 15-02-2004, 12:36
As I just stated, FIRST has said that judging will generally take place after the 10-second 'come to rest period.' If your robot is where it should be by that time, you have nothing to worry about. FIRST has never made a direct ruling as to something which is triggered by power-off (e.g. a solenoid venting), but since you are not controlling the robot after the time ends, there is no problem, and this accoring to the rules so far is 'coming to rest'. Here's a ruling that you may be interested in:
Originally Posted by FIRST QA
Q:Would a hanging robot be scored if, after being powered down, it periodicaly touches the ground, but would eventually settle in a position where it would not touch the ground?
A:"Eventually" is typically about 10 seconds. If objects have not come to rest by then, the referees may disallow its score.
Unread 15-02-2004, 13:17
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
In past years (2000) specifically it was ruled that the judgeing would start after everything has come to a stop... basically if your robot is heading for the floor they will wait to see where it stops... reason has to be applied to this too.. if you cannot easily see that the robot is moveing IE somthing like 1/4" per second or somthing then i wouldent worry as much.. but i think either way i would be a latch on your robot so that when you are up.. your not comming back down. This would eliminate all worries.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 15-02-2004, 14:21
#1067 (SLUH)
Makes sense. We will just do a brake or something to prevent it from sliding . . it barely does as is . . . and it doesn't when the power is off, so maybe we will just look at the jumper on the victor and switch it to stop the slide.
I guess testing is in order, but its not a huge problem.
Thanks for the replies.
Unread 19-02-2004, 22:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They've judged by the end of all motion on the field in previous years(as previously mentioned). So my bet is, you wont get the points.
Unread 22-02-2004, 19:49
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
The Speed controller can apply an electronic brake even when the robot is disabled, this prevents the motor from back driving.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
hanging Gamer930 Rules/Strategy 7 17-01-2004 18:30
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
What year was the hanging bar from? Jeremy General Forum 3 11-01-2004 23:00
Ruler of the Ramp Q & A archiver 2000 0 23-06-2002 22:40
