Go to Post Given the time Banebots has already cost us, what's a little snow? - pfreivald [more]
Unread 25-01-2004, 22:01
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
test autonomous mode
How does one test their autonomous code. How do you set your robot into autonomous mode. Then how do you turn off autonomous remotely?
Unread 25-01-2004, 22:08
Guest
Posts: n/a
Re: test autonomous mode
This is what we did last year:
We created a "key" (as in a wire on a keychain). Whenever we wanted to put our robot in autonomous mode, we would close a circuit between the autonomous mode pin and +5v with the ends of the "key." We pulled out the key when we were done.
Unread 25-01-2004, 22:11
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
my team did this last year too, worked perfectly everytime.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 25-01-2004, 23:20
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
we actually wired that circuit to a switch on our oi last year for testing purposes...
Unread 25-01-2004, 23:49
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Our team created a dongle (basically the same thing) by taking a DB-25 casing and attaching an SPST on the top of it (wiring the same as mentioned above). This allowed us quick usage of the autonomous mode and also made it easy to lend the dongle to others in the pits. I highly suggest this method as it is very easy to build and to use!
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 25-01-2004, 23:51
Guest
Posts: n/a
I was under the impression that input from the OI is ignored when in autonomous mode. So how did you get it out of auto mode?
Unread 26-01-2004, 00:03
How did you get it out of auto mode?
I'm not quite sure what you mean but I'll try to answer:
The dongle was used only to test the autonomous programs so we really didn't have much need to switch out of the mode. Still, if problems did arise, we could simply switch the dongle off and user mode would pop right back up. This became useful at times when program bugs would send the robot scrambling in a random direction on a murderous rampage (which happened more than once)!
One great thing about the OI is that it will read control input during disabled mode. This allows you to give the robot information (such as which program to run) up to the last second before the buzzer. Our team used this to our advantage, allowing us to have 7 autonomous programs (3 switches, binary) that we could choose as we set up the controls and switch quickly if problems came up (we used the last binary position - 0 - as a manual override in the program just in case something went wrong with both the program AND the dongle (quelle catastrophe!).
Unread 26-01-2004, 00:11
for testing purposes, we wired the switch into the competition port, utilizing the autonomous pin and a ground. if it was a close, the robot saw auton_mode = 1 and it would act based on that. When we flipped the switch off, auton_mode = 0 and it would act as if the 15 seconds was over...That's how were wired our controls for testing. We unplugged our stuff from the competition port when we would go to a match.
Unread 26-01-2004, 00:12
Guest
Posts: n/a
Oops, i was asking ShadowKnight.
Unread 26-01-2004, 00:14
does that answer your question?
Unread 26-01-2004, 09:19
theres a schematic to make a dongle that connects to the oi and controls the auto mode, disabling the robot, and the channel it runs on here http://www.innovationfirst.com/FIRST...nout_Guide.PDFPinout Guide
Unread 26-01-2004, 09:24
best thing to do is to wire up the auton and disable switches as the post above suggested
then you will be using auton mode exactly the same as it will be used at the regionals
if you kludge some special user interface switch and let your own code decide when its suppose to run auton mode
you may end up like many teams last year, who thought they had auton mode working great, but it would not work with the FIRST equipment on the field.
The 'competition port' switch setup is the only way to go.
Unread 19-02-2004, 23:02
uzi uzi is offline
uzi is an unknown quantity at this point
can it not be as simple as setting the value of autonomous_mode = 1?
(if not mind letting me know why please!)
Unread 19-02-2004, 23:19
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
yes, you could just hardcode the if/while statement... but I believe autonomous_mode is reset each getdata(), so you'd probably just want to replace autonomous_mode with 1, instead of assigning it
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 20-02-2004, 00:39
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
If you don't have time to do the soldering (or if you're too lazy), setting your team number to 0000 turns autonomous mode on too, if you briefly connect the tether cable between the OI and RC after setting it. You can't turn it off remotely though, since this makes the RC act completely independantly of the OI.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
