Go to Post I emailed Brandon Martus to have my username changed. It was updated within a day. Champion webmaster at work. - Gregor [more]
Unread 17-02-2004, 15:09
1166's Avatar
1166 1166 is offline
AKA: Vex
#1166 (The Highlanders)
Team Role: Animator
1166 can only hope to improve
Send a message via AIM to 1166
Talking About the team numbers
I know they have to be four inches tall and three and a quarter inches wide, but can we use stencils, tape, paint anything we desire?
Merci,
-Vex
Unread 17-02-2004, 15:21
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Re: About the team numbers
Yes, you can use anything so long as it can be seen 100 feet away. Well you cant use tape, as the only tape we are allowed to use is with the electronics.
Unread 17-02-2004, 15:26
1166's Avatar
AKA: Vex
Team Role: Animator
That's what I thought too thanks
Unread 17-02-2004, 16:34
EddieMcD EddieMcD is offline
EddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud of
Actually, I think you can use tape. R14 does say you can't use tape other than electrical insulation, but I think if you are making a team number, it'd fall under the Non-Functional decoration rule (R-55-R60). Someone please correct me if I'm wrong.
Unread 17-02-2004, 16:41
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
You can get into arguments about 'it's there to meet a rule requirement, so its therefor functional', but I think that is not the intent of the rule. The intent is prevent using tape as a fastner.
I would think that using tape to make the team numbers would be fine. Make sure there is contrast.
Wetzel
Unread 19-02-2004, 22:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I dont think anyone will stop you from using tape for your team numbers, but it would look kinda sloppy. Consider the fact that good looking or unique looking robots do stick in peoples minds, so it can be a powerful tool to get yourself to be picked as an alliance partner. Minor details once again can pay off.
Unread 19-02-2004, 23:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It's kind of funny, they say electrical tape can only be used as an electrical insulator, but isn't it an electrical insulator regardless of if it is near electronics? I know I know, the spirit of the rule. I just thought if we were lawyers you could use it wherever you wanted since it keeps its electrical insulating properties no matter where it is.
Unread 19-02-2004, 23:28
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Ok, last year, the rules clearly said #s had to be on 4 sides of the robot. I put it on our robot's left, right, and back side last year. The fourth side was the TOP. Well, the inspectors @ Chesapeake didn't like that so we had to oddly mount it on the front (which had a big gap in it for the stacker) with markers, paper, and tape ... Based on middle school geometry, I would consider TOP as a side
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 21-02-2004, 11:48
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
So no ones gets confused this year, the manual says:
"Teams must display their Team Numbers in four locations at approximately 90-degree intervals around the side of their robot."
So don't try to place the numbers on the top, bottom and two sides ... I'm pretty sure that won't work.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 21-02-2004, 13:20
hcperdan hcperdan is offline
#0135 (Penn Robotics)
hcperdan is on a distinguished road
I noticed in your original question that you said the numbers have to be 3 and a quarter inches wide. Actually the stroke has to be 3/4 inch wide.
Last year we had fancy, fire-rimmed letters, but the stroke wasn't wide enough (the flames didn't count) so we had to overlay the numbers with tape. It wasn't beautiful.
I'm a PHYSICIST, not an engineer.
Step by step walk the thousand mile path.
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
using team 254's field Matt D Western Region Robotics Forum 0 24-01-2003 11:53
How high will the numbers go? you think we'll hit team 911 archiver 2001 10 24-06-2002 03:42
What constitutes the "Best" team? archiver 1999 9 23-06-2002 22:16
RULE CHANGE!!! archiver 1999 11 23-06-2002 22:12
