Go to Post I'm going to get kicked out of the mentor club for this one... - Not2B [more]
Unread 20-02-2004, 00:18
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
pressure regulator
our 120 pressure regulator is only letting us put in 60 - 80 psi. ive turned the nob all the way till it clicks. i know its not my guage because the compressor starts pumping harder at the 60-80psi and i can look on the compressors guage to see that it really is 60 - 80 psi
please help!
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 20-02-2004, 00:20
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: pressure regulator
Er... you are only allowed to be running at 60psi. So I don't see the problem.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
The pressure regulator is supposed to only go to 60 psi. That is the pressure in the system FIRST wants us to have for use in the cylinders. Put the regulators after the tanks, and the pressure switch will automatically shut off at 120 psi.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 20-02-2004, 00:26
Matt Spencer
AKA: Sexy Beast
well it looks like i need to read better. i was under the impression that the yellow tipped one went before the tanks and the other after.
are we aloud to use the yellow tipped as the only pressure regulator?
Unread 20-02-2004, 00:37
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
No, you must use both. The second is a "precautionary" one that FIRST wants us to use, just to be safe.
I just re-checked the pneumatics manual and it states.
Regarding the Norgen regulator:
This Regulator must be placed in-line right after the tanks to limit the pressure to all working circuits to 60psi.
As for the secondary (Monnier valve), this is from the 2003 checklist (I'm assuming it is not going to change):
Monnier Secondary Regulator after Norgren Primary Regulator. Guages veryify system Pressure. 120 psi Tanks; 60 psi System.
Unread 20-02-2004, 00:57
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
What pras means to say is that you need one pressure regulator after the tanks that will regulate the air to <=60 psi. This wouldn't be the yellow tipped regulator(secondary regulator) but the completely black regulator (primary regulator). You do not have to use both regulator but must use the primary regulator between your high pressure (120 psi) and working pressure (60 psi, going through solenoids). You can use a secondary regulator to reduce the psi even farther if you want to but you don't have to use it.
You must however use the Nason Pressure Switch on the 120 psi side of your system. You wire it as a sensor to the RC and it will shut off the compressor at 115 psi and turn it back on at 90 psi. I don't know the specific specs for pins and programming but there is literature about it from FIRST or I am sure there are more people about who have a better idea about that.
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Try putting the high pressure guage on one of the brass T fittings after the pump but before the regulator. You should see it go up to 120 PSI. If not make sure that:
1) you have no air leaks in the system. When you shut off the compressor, the pressure should not decrease
2) you have the regulator installed correctly. There is an arrow on the bottom pointing to one of the outlets. The inlet is the hole directly across from the identified outlet. If you pump air into the wrong hole, it WILL relieve the pressure above 60 PSI.
Eric.
Unread 20-02-2004, 00:58
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Connect your regulator after the reserviors. Be sure it is set with the flow in the right direction (arrow away from your compressor).
The control system, thru the pressure switch, keeps the reservior side limited to about 115 - 120 psi. You must have a pressure gage before the regulator to show that you are staying below 120 psi. Put another pressure gage after the regulator and adjust the regulator to 60 psi max.
You do not have to use both regulators. The second one is an option if youwant to use two different regulated pressures. For example, one cylinder at 60 psi and another at 40 psi.
Take a good look at the pictures in the FIRST manual - they have detail and show a workable circuit.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 20-02-2004, 00:59
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
The only reason I say you must use the secondary regulator, is because it was required last year to use both. Now I'm not sure it is going to be the same this year, it is only an assumption.
Unread 20-02-2004, 01:14
AKA: Nelson Green
I'm sure only one was required last year. I remember a Q&A question addressing this and them replying how the pimary regulator was the only required on and that the one with the yellow ring was optional if you wishes to drop the pressure additionally.
Sorry, I know from reading the current years rule that this is not required this year and their has been no change since last year in this rule.
Unread 20-02-2004, 06:53
Matt Spencer
AKA: Sexy Beast
we arnt putting the compresser on the bot. is it nessecary to have the sensor on the bot or cna we just look at the guague when charging bfore a match
Unread 20-02-2004, 07:42
Rookie Year: 1942
In 2003, we did not keep our compressor on the robot. We charged up before each match and removed the compressor.
You will need a place to connect (the shitoff valve is good) so you can connect and disconnect without losing air. You need the gage on the high pressure side so you know when you are at 120 psi. Then you stil need the regulator to drop you to 60 psi. And you need the gage on the downstream side of the regulator to show that you are at 60 psi.
Good luck with this set up. It worked well for us, but your driver has to remember he / she has only one or two tries with the pneumatics and then you are out of air. Be sure all lines are "filled" by operating the sstem a few times so that you have some pressure in the system - otherwise you can lose all of your air pressure just filling up 'empty' pneumatic lines.
We called our device our R.P.C.A. "Remote Pneumatic Charging Aparatus". MAde a small carry box with a handle and battery. It has come in very handy this season while we tested different circuits.
Chris Fultz
Unread 20-02-2004, 08:54
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Post Re: pressure regulator
Folks,
I know time is running short and panic is setting in... but please don't rely on "I was under the impression" or "This is what we had to do last year". Please do refer to the 2004 documentation.
On the current issue, Section 5.2.9 clearly lays out the requirements of your Pneumatics system. (and you will be inspected against these)
As far as "legality", Section 5 is your primary resource, the Pneumatics Manual your secondary resource. If they disagree anywhere (not saying they do) Section 5 would override.
Hope that helps!
Aidan
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
Pneumatic equations Ghetto_Child Pneumatics 2 13-01-2002 16:42
