Go to Post .. if no one gets ahead no one gets left behind. - Koko Ed [more]
Unread 19-02-2004, 13:01
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Rendering Time
What is the highest Videolengeth:Rendertime:Videosize that a team has had this year?
Ours is about 8Sec:70Hr(Approx.):720x480.
(I hope you can understand what I am saying. (I havent had a decent sleep since kickoff.))
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 19-02-2004, 13:09
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Re: Rendering Time
I'd guess ours is 3sec - 10hr - 720x480 - about 10min/frame, which isn't too bad. You probably shouldn't be getting anything above 20min/frame since this is usually a sign of a poor scene management rather than computational complexity.
Here are 3 steps to bring your render times down:
1) split the scenes in parts. As a general rule, each camera shot gets its own max file.
2) Reduce poly count. delete everything not in sight, subsitute everything in the distance with primitive geometry, and apply multires to everything else.
3) Tune down your GI/raytracer settings. Its pretty hard to tell the difference in quality, but the rendertimes will be cut in half
Unread 19-02-2004, 14:56
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Re: Rendering Time
That's not really true, it more or less depends on the textures in your scene. If you have many materials with reflection and/or a lot of procedural materials (Like the ones I made) your rendertime will be high because of the reflections and having to shift through 18 different levels of bump maps.
Five seconds, 27 hours, about 9-11 minutes a frame was our highest.
I had three computers running on marathon last week to get a 14 second segment done.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 19-02-2004, 15:09
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Rendering Time
7 seconds : 36 hours (640 X 480)
btw....over 20 min...ha...sure you can have a perfectly optimized scene but get over 20 min render time~!!!!! it depends on complexity of LIGHTING (esp) materials and objects....especially if you are doing some really high detail stuff ....like peeps on Cgtalk etc....they sometimes talk about rendertimes of 7-8 hours a frame!
oops...this is Salik Syed not Doug G posting.... sorry
Unread 19-02-2004, 16:40
Re: Rendering Time
Yeah, I've done stills that have taken 8-11 hours to render before. It's not that big of a deal really.
Unread 19-02-2004, 18:34
Lev's Avatar
Lev Lev is offline
Re: Rendering Time
Ok we have a scene with GI, ALL of objects carrying raytrace map, around 300k polycount, and complex particle system with post effects. All of this takes 10 min/frame. You just have to play with the settings - it really pays off.
Umm... thats lack of optimization. The procedurals can be easily rendered to bitmaps, and so can be the 12 layers of bump maps.
Unread 19-02-2004, 22:03
JamesWu JamesWu is offline
#0957 (WATSON)
JamesWu has a little shameless behaviour in the past
Re: Rendering Time
Try to also post your computer(s) specs... I have at most 30 sec per frame and just one 2800+ athlon w/ geforce4 mx440.
I want to start a revolution. Days and Nights were spent wrestling with the impossiblities of typing a word with only one finger. That word is lol, So....use laf.
Unread 20-02-2004, 01:28
Re: Rendering Time
Why would I render layers of bump maps to one bitmap? You completely lose what a procedural is all about. The 12 layers of bump maps would BE what a procedural is. What you're saying is optimization, is poor optimization by decreasing the quality of your materials heavily.
The computers I rendered on were...
Athlon XP 1800+ Overclocked to 2 Ghz
Dual Athlon 1.4 Ghz
Athlon XP 1800+ not overclocked
The Dual Athlon created the fastest render times at about 9 minutes par for the course, the Athlon XP 1800+ overclocked ran 10 minutes, and the non-overclocked XP took 11 to 12 minutes a frame.
Unread 20-02-2004, 01:37
#0957 (WATSON)
Re: Rendering Time
Wow. Your scenes must be very complex mine don't even reach a minute per frame. Do you have everything happening in one scene? Also, what renderer did you use. In my experience mental ray is alot slower than the default scanline, and vray being even faster. Too bad vray is very finnicky. I haven't tried brazil yet. Anyhow tell me what renderer you guys use.
Unread 20-02-2004, 08:52
Lev's Avatar
Lev Lev is offline
Re: Rendering Time
You will only notice quality decrease if you zoom in/zoom out a lot. In most cases you don't. Why would you need 12 layers of bump map anyways?
I do see one case where having procedural with a lot of layers is justified - landscape. It is huge and you are looking at only small parts at a time, and procedurals add good variation to texture. If this is what you were referring to, i agree with you. But for everything else? why?
Unread 20-02-2004, 09:42
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Rendering Time
We stole a nice machine to render on:
-Dual 2.4 xeons with hyper threading
-2 gb of high speed ddr ram in dual banks
-fx 1000 quadro card
-dual 36gb SCSI's in raid 0/15,000 RPM Cheetah HDs
-effective data rate to hard drives 640MBs
Really helps us out alot, rendering is continuing today and tommorrow.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 20-02-2004, 10:48
FRC #0701 (RoboVikes)
Re: Rendering Time
btw....displacement also takes a while.
Yes mental ray sometimes takes a bit longer than scaline it depends on the scene but i actually found that mray is a bit faster also the quality is like 20x better
also just having a raytrace map doesn't make it slow there are some other factors like whether it is transparent reflectivity....btw 8-11 hours is for scenes w/ much higher poly count.... 300k is nothing.. esp if you have trees and what not..., the car alone in the 1st scene is 300k polygons the buildings is like 70 k thhe plants are all very high too i forget the grand total ...
Team 701
Unread 20-02-2004, 12:18
Lev's Avatar
Lev Lev is offline
Re: Rendering Time
This is exactly why i said its always good to reduce polycount. we had a very high resolution car model which was almost 300k, and after reduction it got down to under 80k with no visual quality loss.
Unread 20-02-2004, 14:22
Re: Rendering Time
But if you render out those layers of reflections, bump maps, composites, etc you lose exactly what a procedural is all about.
Unread 20-02-2004, 16:37
Lev's Avatar
Lev Lev is offline
Re: Rendering Time
and what is it about according to you?
time change David Kelly Chit-Chat 14 06-04-2003 23:10
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
time archiver 2000 3 23-06-2002 22:58
Yet another time limit question (about exec summary) Caroline Chairman's Award 1 06-02-2002 17:14
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
