Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Unread 19-02-2004, 23:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Using Accelerometer with '04 controller
I know nothing about programming but can you use an accelerometer to measure tilt with the 2004 control system? I know it can be done in PBASIC but I don't know about C. Don't you need to use trig functions? Thanks.
Unread 20-02-2004, 00:07
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Using Accelerometer with '04 controller
Yes you can. Just make sure your accelerometer's bandwidth extends to DC.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-02-2004, 00:43
-Kevin
DC? As in direct current? I am a bit confused.
Unread 20-02-2004, 01:03
FRC #2429
DC as in zero hertz. You're sensing the constant (unchanging) acceleration of the earth's gravity.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-02-2004, 12:18
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
There are different kinds of accelerometers. One of the most common kind is the piezoelectric (e.g. quartz) accelerometer. These are very useful, but they can only pick up high frequencies, not low frequencies. So if your robot was tilting back and forth at, say, 3 kHz, they would be wonderful. But if your robot is tilting very slowly (say 0.1 Hz), or has stopped in a tilted position (0 Hz) you cannot use this kind of accelerometer. You need to get a different kind.
"DC" in this case refers to the frequency content of the signal coming out of the accelerometer.
/* Daniel */
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Using part of last years EduRobot controller m0rph3us Robotics Education and Curriculum 0 05-12-2003 17:09
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
