Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
  #106   Spotlight this post!
Unread 02-03-2003, 01:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
DIKEM and a scribe. With this and my eyes I can get to within .002 on a Dewalt Mitre saw with a wood blade. (and that was at 2 in the morning!)
Also, that reminds me I like that saw too with the carbide tipped blade. It will zip right through anything except steel but we have a cutoff blade for that.
Also really handy sometimes is my butane pencil torch. Built in igniter, and a fine tip flame up to 2000 degrees F. Not bad.
One really annoying tool is the propane torch without a built in igniter. It is kind of old so it doesn't burn so clean anymore. Our barbeque lighter was out of gas so that option to light it was out. We turned to the good 'ol bench grinder (another great tool) and a piece of steel angle to try to light the darned thing. We turned the gas all the way up and made a shower of sparks bigger than you could imagine but the thing still wouldn't light. Time for a new torch I guess.
TOOLS TOOOLS TOOOOOOLS!!!!!
  #107   Spotlight this post!
Unread 09-03-2003, 15:25
mynameisalex's Avatar
mynameisalex mynameisalex is offline
#0677 (The Wire Strippers)
mynameisalex is an unknown quantity at this point
heh... must I even say?
a WIRE STRIPPER!!!
Actually, last year my freshmanly fascination with this tool is what gave the team its name...
An iguana, perhaps?
  #108   Spotlight this post!
Unread 09-03-2003, 16:41
Dirty Harry
Posts: n/a
Most useful tool? Our giant wrench and our "fart dispersal unit" (a plug-in fan).
But seriously, we really found some good uses for plastic zip ties.
  #109   Spotlight this post!
Unread 20-02-2004, 00:30
c01100011 c01100011 is offline
c01100011 is an unknown quantity at this point
Send a message via AIM to c01100011
Re: Your favorite/most useful tool?
The Slide Hammer . We tap the ends of our drive axels and use this to yank them out or shove them in. Works great and it is tons of fun.
last year my favorite tool was the dremel because it saved my arms from a lot of the "freshman go file" times
i own autocad or wait nevermind it is the other way around
  #110   Spotlight this post!
Unread 20-02-2004, 02:50
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
needle nose plyers to pick all the metal shards out of my hand
i think i have a total of 33 cuts / gashes now
  #111   Spotlight this post!
Unread 20-02-2004, 07:27
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Well, ever since I've been on the Technokat's I have dispised our cordless drills...they could barely cut through plastic!!! Much to my delight, we recently picked up a good ol' 1/2" Makita M-Force 18V cordless drill...now this has to be my favorite tool. You can cut through anything with this drill...and it never bogs down! it's amazing. Just the other day I popped in a 1-3/16" bit(though the top of it is 1/2") for comedy's sake...but it fit! Ooooh yeah. Spins like a charm. Oh yeah, and it's got NiMH batteries...not those annoying NiCd batts that anger me.
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
  #112   Spotlight this post!
Unread 20-02-2004, 10:06
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Milwaukee cordles Sawzall, Milwaukee cordless Drill + Craftsman carbid bits, my 40 year old set of end wrenches, my 30 year old bearing puller, my new pnumatic tubing cutter (hey stick your finger here), and finally a Craftsman Lathe from 1953 that I had to make parts on. Lets not forget a piece of 3 foot pipe for "convincing" stubborne bolts when needed.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
  #113   Spotlight this post!
Unread 20-02-2004, 12:20
Tyler 783's Avatar
Tyler 783 Tyler 783 is offline
Tyler 783
AKA: Tyler Stevens
FRC #0783 (Mobotics)
Tyler 783 will become famous soon enough
Re: New tool
My favorite tool is the lathe that has a plaque on it that says " Conforms to the wartime measures act of 1940. For all those who are not Canadian that act was abolished after WW2.
  #114   Spotlight this post!
Unread 20-02-2004, 12:38
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Deburring tool.
  #115   Spotlight this post!
Unread 20-02-2004, 12:42
My favorite tool is a two-liter bottle of Mountain Dew Code Red. Really kicks the coding part of my brain into high gear!
  #116   Spotlight this post!
Unread 20-02-2004, 12:44
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
I love this 7/16 and 3/8 hex driver I aquired from a verizon guy... Its sorta like a double-ended nut driver. Who needs rachets?
pi is exactly 3
IM me at: zmstr265
  #117   Spotlight this post!
Unread 20-02-2004, 12:46
Marygrace's Avatar
Marygrace Marygrace is offline
School=Build Season YAY
AKA: Mary
#0294 (Beach Cities Robotics)
Team Role: Student
Marygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really nice
Send a message via AIM to Marygrace Send a message via Yahoo to Marygrace
Welder, and my new flowery screwdriver i got for my birthday from a mom from 1115. lol
  #118   Spotlight this post!
Unread 20-02-2004, 13:29
Dorsk65's Avatar
Dorsk65 Dorsk65 is offline
Robots first,Sleep second
AKA: Robert Bloom
#0833
Team Role: Student
Dorsk65 is an unknown quantity at this point
Its gotta be the heat gun, I mean there are so many good uses; Heat Shrink, press fitting stuff, warming food, melting/melding/bending lexan and a ton of other things. But a very close second is the set of hex ball drivers. They smoke normal hex wrenches.
Oh yeah, 5hp Air Compressors are fun...
"It won't work." (or something to that effect)
-Our always optimistic leaders
  #119   Spotlight this post!
Unread 20-02-2004, 14:33
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
can anyone say angle grinder...oooo....sparks :-P
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
  #120   Spotlight this post!
Unread 20-02-2004, 15:28
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
my favorite tool would have to be brut force
Battlebots I.Q.- A serious threat to FIRST or a half thought up cheep copy? Joe Matt General Forum 75 17-10-2005 20:43
tool and part names angier314 Chit-Chat 0 23-04-2003 19:12
What else do we want? archiver 2000 63 23-06-2002 23:19
The popular Dremel Tool. ANY IDEAS? archiver 2000 5 23-06-2002 23:15
A hypothetical Question archiver 2000 11 23-06-2002 22:50
