Go to Post Time flies when you're freaking out. - Koko Ed [more]
Unread 20-02-2004, 14:13
Guilherme's Avatar
Guilherme Guilherme is offline
Guilherme Balbinot
AKA: Guilherme Balbinot
Guilherme will become famous soon enough
Send a message via MSN to Guilherme
Re: #1156 new wheels
Originally Posted by Matt Adams
Just as a heads up: if those plates are made out of aluminum, you may run into distortion in the keyway after repeated use. We had a similar problem on the hub of a large sprocket we were using on our arm this year, and we replaced it with steel after noticing it was enlarging. You may want to explore this a bit more when you start driving.
Overall, a FINE looking design!
Matt
There are two aluminum plates on each wheel, grabing the rollers. The total weight of each wheel is 3,7 pounds, and (guessing) each plate is 1/2'' thick. Do you think we may experience problems even so?
Guilherme Balbinot
Unread 20-02-2004, 20:30
rangersteve rangersteve is offline
AKA: Steve
FRC #0931 (Perpetual Chaos)
Team Role: Student
rangersteve is on a distinguished road
Send a message via Yahoo to rangersteve
Very nice.
reminds me of ours. I personally took a great part in their manufacture. I am very proud. Ours are doubled up but ofset so they run real smooth. But to keep the weight down we had to cut the inard aluminuim down. We overdid it. We were testing the robot without our bumper, hit a the stairs and bend !!! They were easy to fix.
Man i love those wheels.
to see them go to www.robomo.com/FIRST
there is no finished photo but u get the idea.
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
