Go to Post I like to divide checklists like this into "stuff I have to do before applying power" and "stuff I'll find faster by watching it fail". - EricVanWyk [more]
Unread 20-02-2004, 12:19
shyra1353's Avatar
shyra1353 shyra1353 is offline
Class of OT9
FRC #0771 (S.W.A.T. (St. Mildred's Women Advancing Technology))
shyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond repute
Send a message via MSN to shyra1353
Instead of Castors ....
Hi
our robot is finally built and we were driving it for the first time last night .. or i should say trying to because we realized we had to take a part off the bottom of our chassis because it was causing too much friction.
i am wondering what the white-dome shaped things that were seen at the kickoff used on the chassis.
sorry im not being very descriptive but i do not know exactly what it is i am looking for .. only that they are white ..they go on the bottom of the chassis ... they can be used instead of castors ..
if you have the name of them and possibly a place where they can be bought (home depot ??) that would greatly appreciated.
thank you so much and good luck during the last 6 days of build!
shyra
2003 : 771 - SWAT - programmer
2004 : 1353 - The Gizmos - founder/team leader - mechanical head
2005 : 771 - SWAT - team manager and captain - design and construction member
2006: 771 - SWAT - mentor
2007: 912 - Iron Lyons - mentor
if you're going around in circles...then maybe you're cutting corners
aim for the moon and if you miss at least you will land amongst the starts
Email: underscore.asdf@gmail.com
My Website!!
Shirts available for trade: 2005 SWAT 771, 2004 Team 1353, 2003 FIRST Canadian Regional, and 2005 Greater Toronto Regional.
I am also interested in operator/safety captain badges, pins, or any other handouts your team may have given out that you would be willing to mail to Canada.
Unread 20-02-2004, 12:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Instead of Castors ....
I don't think they were dome shaped, but I could be wrong. At any rate, I'm sure they were skids made out of teflon. making your own wouldn't be too terribly difficult. go to mscdirect.com or mcmaster.com and order some etched teflon sheet. then you can just epoxy the etched side to a flat piece of aluminum that you can bolt to your robot.
Unread 20-02-2004, 12:35
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
They may also have been made of Delron, which is a hard, white plastic that is very slippery. You can most probably order it in sheet for, and then attach it to something, or you can order a block of it and cut it to shape. Im not exactly sure about suppliers, but you can check Mcmaster, MSC, and im sure a plastics supply company would have it.
pi is exactly 3
IM me at: zmstr265
Unread 20-02-2004, 14:20
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
go to home depot....pick up some "magic sliders" they are on the same aisle as caster wheels, you got a few days left, waiting around for msc or someone else to ship to you will only delay you further.....get something for the here & now.....
Unread 20-02-2004, 14:29
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
The skids featured in kickoff were made of teflon. Comming from team 263, I have much experiance in this field since for 2001 2002 and 2003 we had 2 wheel drive robots with 2 (or 4) teflon skids strikingly similar to the ones in kickoff.
They work extremely well for quick turning and as a slider for climbing things such as....maybe a step? We used them in 2001 to pull the back of our robot up over the 3 inch step under the 14" bar and never had a problem. If you are to use teflon skids, I would suggest reinforcing them with aluminum behind them to better support the wieght of your robot and if they'll be involved in climbing its always a good idea.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
So Close!!!! Marygrace Chit-Chat 13 21-12-2003 18:16
Building a better caster. Madison Technical Discussion 14 16-01-2003 22:53
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
