Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 19-02-2004, 21:32
roberthan roberthan is offline
None #0702 (Bagel Bytes)
roberthan is an unknown quantity at this point
Send a message via AIM to roberthan
Question How do light sensor(Banner) work?
Newbie here, I'm wondering how do the light sensor work or any demo programs you can give me.
Unread 19-02-2004, 22:16
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: How do light sensor(Banner) work?
take the banner, hook up +5v, GND, and one of the two sensor wires (they are mirrors of each other, one true when the other is false), and plug it into a digital input. play around with it. when the banner sees the line, it will return one value (either 1 or 0), and when it doesn't, it will return the other.
look at the code to map which digital I/O pins are inputs vs. outputs in the default code.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 20-02-2004, 08:27
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
This may be of some help too: http://www2.usfirst.org/2003comp/Spe...nersensors.pdf
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Unread 20-02-2004, 10:18
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Originally Posted by deltacoder1020
take the banner, hook up +5v, GND, and one of the two sensor wires (they are mirrors of each other, one true when the other is false), and plug it into a digital input. play around with it. when the banner sees the line, it will return one value (either 1 or 0), and when it doesn't, it will return the other. look at the code to map which digital I/O pins are inputs vs. outputs in the default code.
This is incorrect. The Banner sensors need between 10 and 20V power supply so you will have to connect them to a 20 amp breaker. Its ok to power more than one sensor from a single breaker. Connect the BROWN lead from all of the sensors to +12V. For each sensor, connect the BLUE lead to the ground pin on the RC and the WHITE lead to the sig pin. The WHITE lead is the normally closed side, so the RC will see a 0 when the sensor does not see the line and a 1 when it does.
I haven't looked into it, but the sensors in this years kit are different than previous years. I don't know if they can be used to see the line or not.
Unread 20-02-2004, 12:40
Computer Guy
AKA: Dav
my bad the sensors should still be able to see the line, though.
Unread 20-02-2004, 17:01
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Originally Posted by seanwitte
... I haven't looked into it, but the sensors in this years kit are different than previous years. I don't know if they can be used to see the line or not.
They are? they look exactly the same to me. The yellow ones, right?
Unread 20-02-2004, 17:59
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Yeah they are the yellow ones. I used them for the wheel encoders this year. The part number is the same. Just this years does not have the schematic on the side. I also think that the sensing indicator led is a different colour.
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 25-02-2004, 13:25
superlou superlou is offline
superlou is an unknown quantity at this point
And you folks are sure we won't fry our board by jamming 12V at it even though its TTL?
Unread 25-02-2004, 13:37
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
You connect to the digital input for the Ground/Signal and 12v for the power.
No problems at all.
5v will not work.
Phil
Unread 25-02-2004, 14:05
Computer Guy
AKA: Dav
No problems at all.
5v will not work.
Phil
yeah, I looked at the banner sensors after I posted and noticed the 10-30V input marker.
FRC Problems, will not work nevrgonastopme0 Programming 4 04-02-2004 21:01
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
light visibility Erinn888 General Forum 30 17-02-2003 15:56
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
