Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 20-02-2004, 21:38
Yellow Eyes's Avatar
Yellow Eyes Yellow Eyes is offline
Programmer
AKA: Brian Novak
#0250 (Dynamos)
Yellow Eyes is on a distinguished road
Send a message via AIM to Yellow Eyes Send a message via MSN to Yellow Eyes
sleep()
In our code, we want to use the sleep() function. When we try to compile we get an error saying it can't find the function sleep(). What would we need to include in order to get this to work?
Unread 20-02-2004, 21:40
Re: sleep()
I dont think you want to use any of the sleep modes - there is code that has to run for the RC to function correctly - the code runs in one continious loop - if you put the uP to sleep, it will stop till an interrupt occurs - I think it would cause the RC to lock up or reset on you.
Sleep modes are normally for low power applications, like PDAs or cell phone - your bot will be drawing 50 to 100 amps during a match, so whats 0.1 Amps more or less going to accomplish?
Unread 20-02-2004, 21:43
Programmer
AKA: Brian Novak
#0250 (Dynamos)
Re: sleep()
what about a pause function? Same results?
Unread 20-02-2004, 21:48
Re: sleep()
same problem, you have to let the main loop run, or the code that is buried in the RC (that we dont see) will say "hey, the user code stopped running, turn off all the victors and relays until it comes back"
( of course it says that in binary: 00011000101010101101101 :c)
Unread 20-02-2004, 22:06
Programmer
AKA: Brian Novak
#0250 (Dynamos)
Re: sleep()
I was just informed it will be sleep(1); will that 1 millisecond make a difference and cause those problems?
Unread 20-02-2004, 23:33
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Re: sleep()
What you could do(for autononmous) was have a start time and an end time to all things. Sort of like this:
//Autonomous code
go(1,0,18);   //Go forward (1 = fwd, 2 = rev), start at 0, and end at 1800ms
turn(1,19,25);  //Turn (1 = left, 2 = right), start at 1900ms end at 2500ms
//Notice the 1000ms delay!
moveArm(2,35,40); //Move arm ( 1 = up, 2 = down), start at 3500ms end at 4000ms
Of course, you'll need to use interrupts (use the white paper from Innovation First), and add a static counter to the t100msDelay, for increments of 100ms. More precision that using seconds. But, the way you should do it is it just sets a pwm (or whatever) equal to the correct value, and move on, when it comes back (you'll have to make it know that it already completed one and it's time to finish up) just set it to 127 or whatever. Very useful and very effective.
Unread 21-02-2004, 21:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: sleep()
So is there a way to 'wait' while still having interrupts going? this would be the easiest way to write a Autonomous Script. You know, Left=255;Right=255;Wait(600);.
Unread 22-02-2004, 10:14
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: sleep()
I'm sorry, but I don't understand what the advantage is of waiting. Why would you need to pause at a specific instruction for some amount of time? What would you need to do in auton mode that couldn't be accomplished by having a state where the drive motors are sent neutral values? You could just be sitting still "waiting" for some input to come your way ... but you don't need to mess with timer's at all. I just don't see the need, so please explain if I am mistaken ...
Unread 22-02-2004, 12:31
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Re: sleep()
There's something called a "FOR LOOP". In this loop, you can specify how long it stays in the loop. You could increment a variable there if you wanted to 'wait' for a certain amount of time. Or, you could use what we like to call a "TIMER". Timers count time. Time can be used for waiting.
Maybe you should be a little more specific on what you're trying to do.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 22-02-2004, 12:43
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: sleep()
but do remember that you need to call putdata every 26.2ms or so, or else the processor will shut down, which would not be a good thing in the middle of a match.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 22-02-2004, 14:51
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: sleep()
If you care, the struture of the for loop is this:
for(initiazation; test; increment)
    // body of loop
It is more flexible than that form indicates, but that would be the most common way to use it. A quick example of it actually being used as a "pause."
// Somewhere at the top
unsigned int i;
// Later on
for(i = 0; i < 10; i++)
    // Do nothing
This code would cause it to loop ten times and then continue.
Note that if you were using this as a timer, it would be different at different battery charges as the controller would run slower.
Anyways, if anyone cares, there it is.
Unread 22-02-2004, 15:18
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: sleep()
instead of going to sleep, i would count loops till the required delay has passed. stoping a program is a bad thing, just because of the way the program loop is structured. if that doesnt work, i would use a timer with an inturupt.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 18:56
Re: sleep()
the microprocessor runs on 5V, regulated from the 12 or 7.2V batteries - and the timing is controlled by a crystal that doesnt care what the battery voltages are
the execution of uP instruction cycles will be dead accurate repeatable, no matter what the state of your battery is, until the battery drops far enough to cause a reset.
I think the people that are contemplating wait states, for loops, do loops or while loops in their code really need to get the default users manaul and get a grasp on how this SW runs
the program takes in inputs from the operator
then it does your processing
then it outputs the results of your processing to the victors and spikes
those three major tasks repeat continiously - you DONT want to pause or stop or put timing delays in your processing area - you want the code to continue to run and loop as fast as it can
so if you are waiting for something to happen, and it hasnt happend yet, then do nothing and check again on the next 'pass' of the SW.
Putting wait states or delays in your code is one of the surest ways to make the controller lock up, and set all your outputs to 'off' - when this happens your bot will go dead and you will have a very expensive, very fancy statue sitting on the field infront of 3000 people.
Unread 22-02-2004, 20:00
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
Re: sleep()
Ok, you'll need two global variables (put them in user_routines_fast.c, or something):
unsigned int delay_count = 0;
unsigned int delay_constant = 0;
enum {PROGRAM_RUNNING, PROGRAM_DELAY} program_state = PROGRAM_RUNNING;
Have a function:
void delay(unsigned int count)
    if (!delay_constant) {
        delay_constant = count;
        delay_count = 0;
        program_state = PROGRAM_DELAY;
    if (delay_count >= delay_constant) {
        delay_constant = delay_count = 0;
    } else {
        delay_count += 26;
This function should be called something like this: (in user_routines_fast.c)
 Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
         if (PROGRAM_RUNNING == program_state) {
             /* Add your own autonomous code here. */
         } else {
             delay(0);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Now, anytime you want to set a delay, simply have a call to delay(milliseconds) somewhere in the autonomous code.
Most of this might not compile.
.. A certain programmer on my team who is unnamed is tooo shy to post this himself! ;D
Unread 22-02-2004, 20:50
AKA: Jamie Bliss
Re: sleep()
My thought was that after it's done waiting, you set a new value. And just do a putdata and a getdata in the loop.
How much sleep are you going to get??? ttedrow General Forum 34 11-01-2004 02:27
Sing me a SONG! Biggs717 Chit-Chat 78 09-05-2003 07:59
Sweet sweet sleep DavidAusTex General Forum 26 25-02-2003 00:38
LET ME SLEEP!!!!! archiver 2001 2 24-06-2002 01:08
Speaking of sleep and dew....see the pic... archiver 2001 3 24-06-2002 00:54
