Go to Post Sweeeetttt.....Thats all that needs to be said. :D - george56 [more]
Unread 20-02-2004, 16:42
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 571 2004 new gearz..
Team311's Avatar
Team311 Team311 is offline
School Is Boring
#0311 (Red Jammers)
Team311 will become famous soon enough
Re: pic: 571 2004 new gearz..
one question are they both gonna be on the robot at the same time
Unread 20-02-2004, 18:16
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
yes. one for each side of the robot. they have output shafts on both sides, so that you don't have to reverse the motor direction on one side of the robot in order to make them run in the same direction like you usually do. makes it run a lot straighter.
the extra output shafts on the trannies (the ones going towards the middle) power the winch. it should lift a little over (i think, but don't quote me on this) 300 pounds? in high gear. that would be 600 in low gear. it goes quite fast, raises at 30 inches/second.
you can't see the shifter, but its there. high gear is 14.5 feet/sec, low gear is 8.5 feet/sec
edit: check out the rest of the bot here
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 20-02-2004, 21:02
Team311's Avatar
School Is Boring
#0311 (Red Jammers)
:edit: I see it is a drill and a globe sorry bout that
Unread 20-02-2004, 22:34
Solace's Avatar
AKA: Jake
no, it is a drill and a Fischer-price
...What is a man,
Jake
Team Paragon #571
Unread 20-02-2004, 22:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm impressed with the transmission. I'm just wondering how you know the plastic gears will handle the job. Because' I'm all for the weight savings if they are strong enough.
Unread 20-02-2004, 22:41
Solace's Avatar
AKA: Jake
they work because the plastic gears are only used for the gears right out of the motors. very low torque at that point, they should be fine.
...What is a man,
Jake
Team Paragon #571
Unread 22-02-2004, 20:10
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
after the UTC scrimmage we have now had good test with the transmissions and the plastic gears held up fine but for precautions we have modified metal ones to take there place
pic: Team 568's 2004 Robot CD47-Bot Robot Showcase 25 22-02-2004 22:09
pic: 2004 drive 930 CD47-Bot Robot Showcase 6 10-02-2004 17:12
pic: Claw of doom (571) CD47-Bot Robot Showcase 10 31-01-2004 08:49
2004 edu controller (PIC) is out! caffel General Forum 13 09-10-2003 23:02
pic: The Full 2004 RC?! CD47-Bot Extra Discussion 7 07-10-2003 17:19
