Go to Post [Programming a swerve drive] It's really really simple, unless you actually do it. - Ether [more]
Unread 20-02-2004, 16:57
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Team light - blinks both colors
Our team light alternates between a red and blue strobe. I have heard that the default strobe is blue. We also have been unable to change the color of the strobe by changing channels. Is there a problem?
Unread 20-02-2004, 17:07
Carpe diem
Re: Team light - blinks both colors
Umm... yeah, changing channels doesn't matter- when you're tethered. Problem solved.
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
hrmmm....i know that when the robot is tethered the team lights blink both red and blue alternally.
when we tested our control system the lights only blinked one color when using radios
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 20-02-2004, 22:33
occra 23.
AKA: ryo
None #1481
ours alternated both with tether and radio.
is that bad?
and how do you attach the lights?
i only see one hole on the back. and no bolts in the kit are the correct size..
can i just drill small holes on the corners to let bolts through?
Unread 20-02-2004, 22:49
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I wouldn't worry about it ours blink both as well.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 20-02-2004, 23:31
AKA: "The Freshman"
Team Role: Operator
If you take the covers off the lights there are 2 spots about the size of button cell batteries, my team just drilled holes in each of these spots for a bolt to go throught and bolted them to mounts attached to the frame rails. It doesnt affect the light or its inner workings so FIRST shouldnt have a problem w/ it.
Unread 20-02-2004, 23:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
It looks as though double sided 3M tape should do the trick, if that's an allowable fastener...
Unread 20-02-2004, 23:36
Imaginary Friend
AKA: Kevin Li
Team Role: Student
We used ruber bands that came with the kit.
Kevin Li
596 - Sciclones
Unread 21-02-2004, 00:51
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
Taken from Innovation First Full-Size RC Reference page 10:
By default, these LED units will display red if you are using the default practice channel of 40. If you
use a channel adapter to change to another radio channel, the team color will differ. Channels 4, 22, and
40 will cause a red team color to flash, while channels 13 and 31 cause blue. In general, the user cannot
control the team color, because it is set by the Arena Controller during competition.
Note that you cannot change the color yourself without a channel adapter connecting competition pin 12 to competition pin 8.
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
What constitutes the "Best" team? archiver 1999 9 23-06-2002 22:16
RULE CHANGE!!! archiver 1999 11 23-06-2002 22:12
