Go to Post It's hilarious to watch this conversation about a box which probably has a 95% chance of being robot batteries turn into all kinds of bowling ball conspiracies. - artdutra04 [more]
Unread 20-02-2004, 22:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Lexan + Heatgun =
Unread 20-02-2004, 22:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Lexan + Heatgun =
That is really cool. We will be making something almost exactly like that tomorrow. I've used a torch before to bend it, one of our mentors says to use a hot metal bar. What kind of a heatgun did you use? Did it discolor or bubble at all?
Unread 20-02-2004, 23:51
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I've done a similar thing to the edges of my model train layout to protect the rolling stock in case of a derailment so it doesn't end up on the floor. I used 1/4" Lexan and heated it with a heat gun to match the contour of the edge of the layout. I have a variable temp (200-1200 degree) Milwaukee heat gun. I started at a lower heat and held it about 6" from the piece and slowly tried to bent it. I'm guessing I bent it around 350 degrees with the heat gun several inches from the Lexan. The amount you hold the heat gun over the piece will depend on the thickness of the material, the temp you're got it set at, and how far away you are from the piece. It's best to try it on a scrap piece first. Just remember some plastics are combustable.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 20-02-2004, 23:56
Ben Lauer's Avatar
Ben Lauer Ben Lauer is offline
Seshambeh Dareh Meyod
Ben Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond repute
We have a "machine" that has a strip like one in an oven the heats the lexan. We just lay it flat on it for about 15 sec, then bend and tah dah!
Unread 21-02-2004, 00:19
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
We used a 1300w heatgun. The board got a little tweaked from some areas getting hotter than others, but you cant tell it with out feeling the board. As for discoloring and bubbling, nah. The Lexan was 1/8" thick .. and took about 10 min to heat up the 34" strip of it. We had it clamped to the table with a 1x1 aluminum tube and some clamps on each side, and then one kid had a large 2x4 to bend the lexan.
Keep in mind, that lexan is flammable after 800 degrees (at least thats what the warning said on the plastic cover) So dont get it too hot .. and practice a few times on a spare piece, because it is a little tricky, and if you've never done it, you might wreck the expensive lexan.
Good luck.
(Edit)
Heres a picture of the setup we used to bend it ..
http://www.eaglerobotics.com/images/...an_bending.JPG
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
