Go to Post I have a pocket full of Gracious Professionalism! How about you? - Schnabel [more]
Unread 19-02-2004, 15:06
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
Thumbs down line seeking help needed
I have this and i know it works but i have 3 digital ins that are set as inputs
rc_dig_in01
rc_dig_in02
rc_dig_in03
they are all optical sensors, i know the optical sensors are working properly becuase i get on and off lights on the operator interface. I just cant seem to "word" the way to get all 3 sensors to work together.
roughly i want tit to work like this
if dig in 1 is on then it should turn left
if dig in 2 is on both motors should dturn equally
if dig in 3 is on then it should turn right
PWM01= left side drive
PWM02= right side drive
... but how do i get the sesors to all work together.
I cant seem to think on how to get them to all work together i tried a switch statement and stacking else if 's i just cant think of how to get it to work.
if (rc_dig_in02 == 1) {
    pwm01= 200;
    pwm02= 200;
else {
    pwm01= 127;
    pwm02= 127;
Unread 19-02-2004, 16:04
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: line seeking help needed
i think what you are trying to do is
if (rc_dig_in01 == 1) ||  (rc_dig_in02 == 1) {
    pwm01= 200;
else {
    pwm01= 127;
if (rc_dig_in02 == 1) ||  (rc_dig_in03 == 1) {
    pwm02= 200;
else {
    pwm02= 127;
jerrw w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 19-02-2004, 16:16
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
Our head programmer suggested:
if (rc_dig_in02) {
	pwm01 = 200;
	pwm02 = 200;
} else if (rc_dig_in01) {
	pwm02 = 200;
	pwm01 = 127;
} else if (rc_dig_in03) {
	pwm02 = 127;
	pwm01 = 200;
}else {
        /* No line found.... */
Unread 19-02-2004, 16:20
MisterX's Avatar
Alumni
AKA: Mr. X
FRC #0521
Thank you both for your fast reply I will test both of those now and let you know when I get my results. THANK YOU SOOOOOOOO MUCH!!!! and best of luck to both of your teams.
Heres the code i ended up using:
if (rc_dig_in02) {
	pwm01 = 200;
	pwm02 = 200;
	pwm02 = 200;
	pwm01 = 127;
	pwm02 = 127;
	pwm01 = 200;
} else {
    pwm01= 127;
    pwm02= 127;
and it works perfectly thank you for your help
Unread 20-02-2004, 10:12
Catastrophy Catastrophy is offline
AKA: Vince
#0704
Catastrophy is an unknown quantity at this point
Send a message via AIM to Catastrophy Send a message via MSN to Catastrophy
Hey Mister, just a suggestion, the more sensors you have on your robot for line following, the more accurate, and the faster you can run it. We're using 9 sensors and we can run at almost full speed with about a 95% of the time staying on the line.
Unread 20-02-2004, 10:18
MisterX's Avatar
Alumni
AKA: Mr. X
FRC #0521
Wowser, and to think originally some of my team wanted to only do two and we had to convince them three was better. Thanks for the information Catastrophy I'll probably try and work somethign like that during the offseason but right now with the little time we have left we will probably stick with three unless a miracle happens. Thanks for the info though, I would love to try something like that.
P.S. if you are at Nats do you think me and one of my other programmers could swing by your booth to check it out? P.M. me
Unread 20-02-2004, 16:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I don't think 9 is necesary, but trim the positions of the sensors based on the width of the line. I think 5 would be good:
1  2| 3 |4  5
1,5- perimeter, just to make sure your bot doesn't get lost.
2,4- if these hit the line, turn that way.
_ 3- Keep this on the line.
ps-the code was just to get a fixed-width font.
Unread 20-02-2004, 19:00
AKA: Vince
#0704
Heres a tip if your having problems staying on the line, make it go in reverse if no line is being read. Heres a picture of the temp configuration (gonna have a metal plate for final all neatly up under the hood. and holes in chasse for beam to get out.)) and a video of this year's sensors on last year's bot. The video is kinda bad example of how the code's working, the video is 15 sec, but it usually only take 7-11 seconds to get to the ball stand
http://home.comcast.net/~Catastrophy/picture.jpg
http://home.comcast.net/~Catastrophy/movie.avi
Here's the code tweaked for our bot if anyones interested.
		if (dig12 == 1 && dig18 == 1){
			pwm14=76;
			pwm16=76;
		if (dig18 == 1 && dig1 == 1 &! dig12 == 1 &! dig6 == 1){
			pwm16=96;
			pwm14=115;
		if (dig18 == 1 &! dig1 == 1 &! dig12 == 1){
			pwm16=86;
			pwm14=115;
		if (dig1 == 1 &! dig18 == 1 &! dig6 == 1){
			pwm16=76;
			pwm14=178;
		if (dig12 == 1 && dig4 == 1 &! dig18 == 1 &! dig10 == 1){
			pwm16=96;
			pwm14=115;
		if (dig4 == 1 &! dig12 == 1 &! dig10 == 1){
			pwm16=178;
			pwm14=76;
		if (dig12 == 1 &! dig4 == 1 &! dig18 == 1){
			pwm16=115;
			pwm14=86;
		if (dig1 == 0 && dig4 == 0 && dig12 == 0 && dig18 == 0 && dig8 == 0 && dig10 == 0 && dig6 == 0){
			pwm14=155;
			pwm16=155;
		if (dig6 == 1 &! dig1 == 1){
			pwm14=204;
			pwm16=50;
		if (dig8 == 1){
			pwm14=127;
			pwm16=127;
		if (dig10 == 1 &! dig4 == 1){
			pwm14=50;
			pwm16=204;
Unread 21-02-2004, 01:33
boostaddict boostaddict is offline
boostaddict is an unknown quantity at this point
for those that actually have this working on the 2004 bot, what times are you getting to track the complete line?
Unread 21-02-2004, 07:09
Jamie_Richard's Avatar
Jamie_Richard Jamie_Richard is offline
I'm IN - RIT HERE I COME
#0782 (The Kilowatts)
Team Role: Student
Jamie_Richard is an unknown quantity at this point
Send a message via AIM to Jamie_Richard
This looks excellent, after sitting around looking out our programmers figure out nothing last night this is a breath of fresh air. I personally am not a programmer, but I am going to try to implement this tonight after the Suffield Scrimmage. We were using two sensors, and something didn't seem right about it, does anyone have any reccomendations, when using three sensor, on how to make the robot go backwards if its not seeing the line. I have a very limited knowledge of C, and I feel our programmers are uncomfortable with the platform this year. so...
If you guys can help me make this work, there will be Krispy Kreme's at Hartford (or Atlanta) for you, on me.
Thanks a Bunch!
Jamie
DOO-DOO-DOO - Team 7-8-2 will not be competing in the 2005 FIRST Season. Please make a note of it.
Unread 21-02-2004, 07:23
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Thanks a Bunch!
Jamie
Catastrophy might have a more advanced solution, but basically, if you don't see the the line with any of your sensors, reverse. Something like this:
if(rc_dig_01 == 0 && rc_dig_02 == 0 && rc_dig_03 == 0)
   pwm01 = 0;
   pwm02 = 0;
You would, of course, have to add the code for actually following the line, but that is basically all you have to do to reverse if you don't see anything on the sensors.
PS the digital inputs are your sensors and the pwmXXs are the drive motors.
PPS Nine banners. Crazy.
Unread 21-02-2004, 08:04
Team1425's Avatar
Team1425 Team1425 is offline
#1425 (Wilsonville Robotics)
Team1425 is an unknown quantity at this point
Our team is actually going with two custom built analog sensors, we like analog because its not just a 1 or a 0, it brings back a range as it slides on and off the line, so you can actually program for it to follow a line quite fast with only one sensor as opposed to having 3 - ... 9 sensors
Our sensors have a potentiometer on each that allows us to adjust the sensitivity and they each have their own LED light, so they could even follow a line if it were in a dark room. (not that following lines in the dark is useful for the competition, but its something its capable of)
Unread 21-02-2004, 12:38
AKA: Vince
#0704
If anyone has any questions on line following please feel free to PM me or IM, i'd be happy to help with what I can.
P.S. I extremely recommend using atleast 3 sensors for line following, with 2 the bot will not act right at all, will be very jittery.
P.P.S the more banner sensors you have the better it will work. I've learned from personal experience.
Unread 21-02-2004, 19:42
AKA: Jamie Bliss
The ultimate engineering attitude: "Why? 'cause we can." Why not?
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Q&A Discuss: Does the line continue up the ramp? CD47-Bot Extra Discussion 5 18-01-2003 01:01
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
approach to autonomy Mike375 Programming 32 08-01-2003 14:04
emulationFIRST v0.04 Matt Leese Programming 7 09-07-2002 08:54
