#9
Re: Major mechanical problems....
can you give a more exact description of your drivetrain? What gear ratios do you have? What are you using to acheive these gear ratios? Is there any misalignment anywhere? Your explanation is a little confusing?
Oh and btw to answer your question about drills vs. chips, they both have their place. The drills are i believe slightly more powerful than the chips. The drills have a much higher free speed and a much lower torque output. The chips have much higher torque and much lower speed. The CIMs are much more reliable and durable than the drills. |
| Most computer problems... | Joel J | Chit-Chat | 6 | 27-11-2005 16:58 |
| If you're having MPLAB problems, LOOK HERE. | Jeremy_Mc | Programming | 0 | 20-01-2004 18:06 |
| Do you all have problems with.... | Munkaboo | Website Design/Showcase | 19 | 03-03-2003 19:51 |
| Joystick problems | archiver | 2001 | 3 | 24-06-2002 02:40 |
| Radio problems -- not | archiver | 2000 | 1 | 23-06-2002 22:23 |
