Go to Post If they had kids, they would be a super-breed of robot builders and drivers, and would win dozens of awards per season. - smurfgirl [more]
Unread 02-02-2004, 11:26
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: smoking drill motors?
Originally Posted by Joe Ross
Initially, there was no rule against it, then there was an update that STRONGLY suggested not doing it. This year, as Al linked, they specifically tell you not to do it.
From Team Update 7 last year.
Cautionary Note About Skill-Bosch Drill motors!!!!!
DO NOT attempt to unsolder the wires that are attached to the Skill-Bosch motors. The plastic housing that holds the brush assemblies will be damaged if you do. The high temperature of the soldering process causes the plastic to deform and destroys the motor. Teams should make their electrical power connections to the motors’ pre-attached wires, not directly to the brush holders.
Regardless, letting out the magic smoke is always a bad thing. Most of the above posts have covered the various ways to do this.
Wetzel
Unread 22-02-2004, 08:54
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
My team just had this problem last night. We were driving the robot around for some testing, and about 3-4 minutes of driving it around on a cement area in the middle of our school, we noticed smoke from the motors. We checked it out and there was definitely smoke coming from the motors and a very strong smell of it. We have one large muffin fan mounted above each drill motor, although we noticed a large amount of escaped airflow, we thought this might be the problem, so today we are going to fabricate some air ducts. Does anyone else have any suggestions? We did not disassemble the motors and I do not believe there was any drilling on the chassis around the motors.
Also, we noticed that there was a lag with one wheel, so it skips three or four times at acceleration and then moves slower than the other wheel as we drive around. I know that the other wheel's gearbox is greased up, and this one's isn't. Does anyone know what else might cause this problem?
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 23-02-2004, 13:59
This is very typical of some designs. You do not say what your configuraion is so I am going to assume four wheel tank or two wheel with non steering two front wheel. These types of drive systems use incredible amounts of current when turning. Again, if there is any friction in your drive train it will manifest itself as high current in the drill motors. Can you describe the drive train or include a picture?
Unread 23-02-2004, 14:18
Ben Lauer's Avatar
Ben Lauer Ben Lauer is offline
Seshambeh Dareh Meyod
Ben Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond repute
Magic Smoke, Magic Smoke, Run For You Lives, You Released The Magic Smoke!!!!!!!!!
Unread 24-02-2004, 09:21
Joshua May's Avatar
Go Bears!
We have vertically mounted drill motors, connected to the kit's gearbox with a 2:1 gear ratio. The output axle of the gearbox runs to one of the kit's 12.5" pneumatic wheels. I will try to get a picture up soon, I have none with me at the moment.
Thanks for your help.
Unread 24-02-2004, 10:38
jjv jjv is offline
jjv is an unknown quantity at this point
Do you have your gear boxes aligned so that when the bot is going forward, both motors are going in their forward direction? Or is one going forward and the other in reverse? If this is the case, that would explain the lag between the two wheels. These motors are more efficient when run in the forward direction, so if one runs opposite the other it will do so unevenly.
Unread 24-02-2004, 17:11
Joshua May's Avatar
Go Bears!
I will make sure to check up on this when I get to the robot. We will check once more on the driving and then I will see about this, I hope it's not too hard of a fix...
Unread 01-03-2004, 23:32
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Our 2001 drill motors would smoke quickly whenever we stalled them (like driving into a wall, and maintaining full power to the motors). The 2004 motors are different, but I suspect they would do the same.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
Blowing drill motors archiver 2000 6 23-06-2002 21:58
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
