Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 21-02-2004, 11:52
reisser's Avatar
reisser reisser is offline
Ph.D. User
AKA: Brandon Reiss
#0103 (Cybersonics Technology Team)
Team Role: Animator
reisser is on a distinguished road
Send a message via AIM to reisser
Compression Crisis
Has anyone else done any test exporting to the DV .mov file type? I am experiencing a severe loss of quality and pixelation. This does not occur to near the degree I am seeing if I use a Windows AVI with the DV codec.
I am using Adobe Premiere 6.5 to export uncomressed targas to the DV/DVCPRO Quicktime codec at 720 x 480.
Doctor?
Unread 21-02-2004, 14:43
swando swando is offline
#0217 (ThunderChickens)
swando is on a distinguished road
Send a message via AIM to swando
Re: Compression Crisis
im using the exact software and settings as you, im getting flashing and pixelation using the cinepack codec (you know, the required one.)
it sucks, but its what they want. i wish they would let us use AVI.
cluck.
Unread 21-02-2004, 20:30
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
Having the same problem too. Quicktime DV/NTSC codec is bad. The Quicktime Cinepak one is even worse. We'll submit it like that though. Just as a comparison, we exported our animation in the sorensen 3 codec (which comes with quicktime), and it was 1/3 the size and 10x the quality at least. That'll probably be the version for our own keeping and the internet version.
Unread 21-02-2004, 20:43
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
We rendered everything in .mov and then transfered via pen drive to an ibook and used imovie to compile everthing. Worked pretty good.
Unread 21-02-2004, 21:53
Ericente's Avatar
Ericente Ericente is offline
yeah, that's me.
None #0157 (Aztechs)
Team Role: Student
Ericente is on a distinguished road
From my experience, iMovie isn't able to import quicktime files (not iMovie 2, at least) what version of iMovie are you using?
That clock says 18 degrees.
Disclaimer:
The thoughts stated in the above post do not represent the anything of anyone.
Unread 22-02-2004, 00:16
JamesWu JamesWu is offline
#0957 (WATSON)
JamesWu has a little shameless behaviour in the past
When I render dv/dvcpro quicktime in premiere I get bad artifacts and when I use Cinepak I get nasty pixelation. So, I tried rendering high quality mpeg4 then I went into 3dsmax and used Videopost to render it into a dv/dvcpro-ntsc format, everything looked clear, but there were digital looking artifacts everywhere.
I want to start a revolution. Days and Nights were spent wrestling with the impossiblities of typing a word with only one finger. That word is lol, So....use laf.
Unread 22-02-2004, 10:39
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
So far, it appears that I am getting good results using an uncompressed AVI as an environment map in 3ds max and rendering to a .MOV. For whatever reason, the encoder used in Premiere is terrible and the one packaged with max seems to work. I wish Autodesk had addressed this in the rules. Especially because most of us render to frames and use some sort of video editing software to encode.
-Brandon
Doctor?
Unread 22-02-2004, 10:42
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
We rendered in Premiere using Cinepak, and our file size was just fine as well as the quality. I'm not sure what you guys are doing, but I'd try using Cinepak..
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 22-02-2004, 10:47
AKA: Nelson Green
Not for sure on version, but I know it accepted them and worked pretty good.
Unread 22-02-2004, 11:23
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
If youre still having problems then I'd try using an input event with an uncompressed AVI in the video post, a sound controller in the track view, and an output to a .MOV file.
That worked for us. Best results using Cinepak at full quality. 99.7MB.
Doctor?
php and gzip compression Trashed20 Website Design/Showcase 2 12-06-2003 22:11
Audio compression... Ranma 3D Animation and Competition 5 05-03-2002 23:25
