Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Unread 22-02-2004, 06:52
Natedude's Avatar
Natedude Natedude is offline
#0824 (Students Working Against Time (SWAT Robotics))
Natedude is an unknown quantity at this point
Send a message via ICQ to Natedude Send a message via AIM to Natedude Send a message via MSN to Natedude
Question OI jog switch
I'm looking for a type of control (potentiometer 100k) that auto centers when you let go of it. The idea is to center it at and have it decrease/increase resistance as you turn it CCW/CW but auto center at a middle value (50k) thus providing the digital 127-ish value.
The idea is to use this with a motor to steadily increase speed in one direction or another as you rotate it further in a CCW/CW direction. Also to not provide power to motor when the switch is let go of (it stops).
Any ideas on a manufacturer of this kind of switch? or a term to search on google.com like "jog switch"? Anything helpful? Anyone? (I'm desparate for help )
Unread 22-02-2004, 11:08
Re: OI jog switch
Joysticks do it by using a simple potentiometer, and then springs attached in both directions. When you let go, the springs push it back to neutral.
Unread 22-02-2004, 13:05
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Re: OI jog switch
you might have to take apart last years joystick and use it.
i do know that what your looking for exist somewhere because i have seen them but i dont know what they are called
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 22-02-2004, 14:40
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: OI jog switch
i have seen a similar switch on some VCRs, you may wana go dumpster diving
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 17:13
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: OI jog switch
Maybe this? http://www.precisionsales.com/rocker.html its a "rocker pot" that looks like a rocker switch, but its analog instead of digital. Is a custom job so you got to email the manufacturer eparts@ix.netcom.com
or this http://www.4qd.co.uk/accs/pots.html
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
Beacon selector switch? How to find/make? Fen Programming 13 12-02-2004 16:31
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
