Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 25-02-2002, 14:08
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Upright???
I see a lot of robots that seem to have a different understanding of what upright means.
Am I wrong or is there not a requirement that the light be mounted more or less vertical?
Joe J?
M8. Robots must use the rotating light provided in the kit to display alliance color (red or blue).
The light must be mounted upright on the robot such that the color is visible in at least 4
locations 90 degrees apart around the sides of the robot from a distance of at least 50 feet.
The light should be mounted to allow easy changeover of the colored lens before matches.
See Section 2.1.2 for wiring information.
Unread 25-02-2002, 15:11
asher asher is offline
None #0031
asher will become famous soon enough
We mounted ours sideways off our arm last year and never had a problem, I doubt FIRST would really force you to change it unless they felt it was in an area to be broken, remember their are a lot of rules they don't enforce, I think this one will be added to the list.
asher
Unread 25-02-2002, 17:05
jrukes jrukes is offline
no team (none)
jrukes is on a distinguished road
We mounted our light on the side until I checked the rules again. Last year, the rules was the light must be visible from 4 sides. This year, they added the term UPRIGHT, specifically. It is even mentioned on the Inspection Check List as "Changeable rotating light (Red & Blue) easily accessible, visible from 4 sides of robot and mounted upright."
I'm not sure why they would be so specific this year, but ... we moved the light to the UPRIGHT position just to be safe.
-Jason
Unread 25-02-2002, 17:41
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
light visible on 4 side
Pretty much the reason FIRST want the light upright is to make sure spectators from all 4 side of the arena a easily identify which alliance a team is on. Last year wasn't as important because it was really ONE alliance on the field, and the light color only used for the 1.1x multiplier when scored a big ball.
It was great to seperate which team is which when the accouncer called out teams' name, and good for scouting to easily identify which robot they should be doing... But the light wasn't necessary last year.
This year, the light is supposed to help spectators to easily understand the dynamic of the name. So that they will understand when 2 red is pushing against a blue robot while the other blue robot go for balls, etc.
I really do suggest teams mount their light upright, because chances are, FIRST will require you to put it upright if you didn't already do so.
Unread 28-02-2002, 08:50
loworbit
Posts: n/a
The reasons for mounting the light upright, could also be the aggressive nature of the competition this year. When First recommends bumpers around the robot you know things are going to be viloent. Anyways, in the past year they introduced a light that is held on by velcro, not a belt, while they are much easier to change, they could easily fall off when mounted upside down or pointing to the side.
Unread 17-03-2002, 14:39
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
we mounted ours sideways and they made us change it... good thing, too, because it would've gotten destroyed
TEAM 30 - FURY
p.s. our robot is a beast
Unread 09-04-2002, 23:43
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
I've seen the lights on their sides at the EMU and Canadian Regionals...The upright rule definately wasn't being enforced.
Altho, it might have been an idea to; covers were tending to fall off of the bot's with them sideways.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 10-04-2002, 23:29
mike pawlak mike pawlak is offline
mike pawlak has a little shameless behaviour in the past
Send a message via AIM to mike pawlak
alls i know is that a lot of teams lights didn't even work. this was very frustrating to watch
light visibility Erinn888 General Forum 30 17-02-2003 15:56
You want a piece of me??? Joe's Tote Joe Johnson General Forum 39 08-04-2002 18:51
