Go to Post I would like to think that I would be considered smart no matter who I was. - Kelly [more]
Unread 22-02-2004, 16:11
nick_champ_2 nick_champ_2 is offline
AKA: Nick Reed
FRC #2902 (Nyack)
nick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the rough
Send a message via Yahoo to nick_champ_2
Exclamation build new programming (st.louis regional)
could someone who knows how to program the bot (that is comming to the ST. LOUIS regional) please program our robot. we are using the default code and we have some additional things that need to be worked into the program but none of our team members know the language. anyone else that wants to help my e-mail is nickmesa2005@yahoo.com
we need programming for 1 joy stick to go forward, back, and turn with two different pmw ports (drill motors)
two different buttons to reel in cable for different things (2 seat motors)
one button to turn van door motor.
at a total we have 5 motors and need three different buttons with the
x and y axis working correctly. thanks
PLEASE
Unread 22-02-2004, 16:52
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: build new programming (st.louis regional)
Im sure someone will, but id recomend you check out FIRSTs C programming tutorial so you arnt stuck next year.
http://www.usfirst.org/robotics/C_help.htm
It helps some if you have someone that did pbasic (assuming your not a rookie team ) because its not all that diffrent, its just daunting at first but youl get the hang of it.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 17:29
AKA: Nick Reed
FRC #2902 (Nyack)
we have a teacher that will try to help but he is taking his time with it and we need it like NOW
Unread 22-02-2004, 18:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Could you post what signals are connected where?
Ie. joystick 1 y is the right drive command
pwm1 is connected to the right drive motor (0 = full forward, 255 = full reverse)
or something?
Based on your second statement, I am assuming that you want code now, not when you get to St. Louis.
Unread 22-02-2004, 19:59
Linux Guy
AKA: maxdamage
EDIT: I sent you an email and a PM
Unread 22-02-2004, 20:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
You have a month to program after you ship the bot.
Unread 22-02-2004, 20:47
Linux Guy
AKA: maxdamage
they may want to do some driver practice.
Unread 22-02-2004, 21:06
AKA: Jamie Bliss
That is the problem. But ship is on thursday. Show up early.
Unread 22-02-2004, 21:33
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
PLEASE
nick, are the seat motors and the van motor on victors or relays?
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 22-02-2004, 21:37
AKA: Jamie Bliss
:blink: :blink: victors, but thats another forum.
We use relays for solenoids.
Unread 22-02-2004, 21:40
Linux Guy
AKA: maxdamage
I think he was asking nick_champ_2...
Unread 22-02-2004, 21:41
Computer Guy
AKA: Dav
never hurts to double-check. would you dive headfirst into a programming project without knowing exactly and for sure what you're programming for?
Computer Guy
AKA: Dav
that i was.
Unread 22-02-2004, 21:42
AKA: Jamie Bliss
Yes. Use aliases.
Unread 22-02-2004, 21:43
Linux Guy
AKA: maxdamage
er... are you ok?
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Break Down of Awards By Fields. Josh Hambright Championship Event 13 09-04-2003 10:22
Regional Team List Jack General Forum 5 03-01-2003 12:05
The 'Big Picture' regarding regional space.. archiver 2000 1 23-06-2002 23:58
parts sharing at Silicon Valley regional Ken Leung Regional Competitions 2 26-03-2002 01:19
