Go to Post Now I have yet another webpage that I will feel the need to constantly check - rachelholladay [more]
Unread 22-02-2004, 12:09
bob1million's Avatar
bob1million bob1million is offline
#0825 (Swivvey-gus Maximus)
bob1million is an unknown quantity at this point
Bouncing turns
We just had our first practice with our bot running and when we try to turn it it bounces out of control. It is four wheel drive and we used the wheels that came with the kit.
Is there anyway to stop it from bouncing and make it turn smooth?
"Death smiles at us all, all a robot can do is smile back."
Unread 22-02-2004, 12:12
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
Re: Bouncing turns
I am currently working with 406 and we had the same problem. In order to fix that problem we found that replacing the front tires with some that have a smooth surface will give you a nice smooth turn.
Unread 22-02-2004, 12:13
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Bouncing turns
Try increasing the tire pressure.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-02-2004, 12:20
David66's Avatar
David66 David66 is offline
YA TOAST!
AKA: David Butzin
FRC #0066 (The Flyers)
David66 has a spectacular aura aboutDavid66 has a spectacular aura aboutDavid66 has a spectacular aura about
Send a message via AIM to David66 Send a message via Yahoo to David66
Re: Bouncing turns
A few weeks ago we had the same problem. It is caused by friction with the carpet. If you place the robot on a tile surface and drive it you will find that the bouncing does not occur. We were not able to find a way to negate this bouncing with the pnuematic tires, but rather went to a wheel with a low friction surface and it works great. If you have any other questions fell free to IM me on AIM: DavidButzin If I can't answer questions you have chances are I will be able to direct you to someone who can. Hope this is helpful!
Proud Alumni of Team 66
2005 Great Lakes Regional Champions with Team 67 (HOT) and Team 68 (Truck Town Thunder).
2005 West Michigan Regional Champions with team 107 (Holland Christian High School) and Team 93 (New Apple Corps)
2002 National Champions
Unread 22-02-2004, 12:29
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Bouncing turns
Last year we put casters on pneumatic cyclinder on back to lift the back wheels barely off the ground. This year we fully inflate the tires and just deal with it. There are several good solution to this including completely inflating tires and changing a set of tires so that they will slide sideways but still drive forward. Omni-wheels of sorts (not really, unless you can make them quick) But something that has less contact with the ground but still can grip forwards.
Unread 22-02-2004, 12:49
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: Bouncing turns
It sounds like you're having the ever popular trouble with 4 wheel drive turning. Chris Hibner wrote a really good white paper to help solve this problem. If none of the quick tips here work, I'm sure some of the information in this white paper will help.
Unread 22-02-2004, 18:30
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: Bouncing turns
That white paper doesn't appear to be available at the moment.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 22-02-2004, 19:28
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Bouncing turns
This was a problem at the UTC scrimmage 716 was bouncing out of control they didn't have the problem as bad after taking most of the air pressure out of there tires. Increasing the pressure made it bounce higher. even though really hard to control it looks rather amusing
Unread 22-02-2004, 21:32
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Bouncing turns
-Kevin
just like he pointed out.... get more pressure on your tire... about 35 psi.
Unread 22-02-2004, 21:34
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Bouncing turns
there IS another option... shave down the wheels!! or mabye get some teflon and start wraping them...
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 21:39
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Bouncing turns
Yea, we noticed this problem back in week 2 durring our first trial run, we fixed it by putting casters on pnumatic cylinders. On carpet we are always in caster mode but when we climb or we are on the platform we are on awd mode.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 22:00
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Bouncing turns
You can't very well shave down pneumatic wheels now can you?
Unread 22-02-2004, 22:17
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Re: Bouncing turns
Well, at the DC Scrimmage last Saturday, I saw quite alot of bots w/ this problem...
Luckily ours wasnt one...
But anyway, the 12" pneumatics wheels seem to be used ALOT this year. Mainly, I would assume to climb the platform from the side, which based on last weekends results, isnt going to work quite as well as people would hope...
We personally stick with our 8x2" wheels, spaced out 26" wide (roughly)
I'm not too sure how to eliminate the issue. If you're not planning on going up the platform, try to get some smaller wheels with a little less traction. Or, you could make 2 big omni wheels for the front or back 2 tires of your bot using a bunch of smaller omnis.
I would make sure your tire pressure is full though. That was an issue with a few of the 12" 4x4 bots...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 22-02-2004, 23:24
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Re: Bouncing turns
someone posted earlier that they painted the back wheels with poly somthing or another. the robot will rotate around the front wheels because the back ones slip.
also with the tire pressure deflate the front ones and inflate the back ones. you want it to rotate around one wheel set and slide the other.
we just stuck some casters on the back that come up when we are climbing the platform
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 22-02-2004, 23:27
Re: Bouncing turns
Somoene actually suggested using a wax type substance like armor-all on the tires? Would that work, or be legal?
Disney turns away visitors on Segways Clark Gilbert Dean Kamen's Inventions 8 19-02-2004 22:07
Image Discuss: 294 Teaser, it turns? CD47-Bot Robot Showcase 3 03-02-2003 16:56
Pneumatic..Schematics..are bouncing everywhere archiver 2000 0 24-06-2002 00:38
Bouncing heads.... archiver 2001 2 24-06-2002 00:14
Competition Name? archiver 2000 11 23-06-2002 22:09
