Go to Post At every event I've seen this year, there has been at least one robot that left a part on the field. Even some of the robots have decided they don't want to play and this year and made a break for it in autonomous! :yikes: - ctt956 [more]
Unread 22-02-2004, 17:36
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 356's Little Black Box
Unread 22-02-2004, 17:37
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: pic: Team 356's Little Black Box
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
So you got a radio shack project enclosure and (what looks like) a serial connector, may i ask what this is used for???
-Michael Dessingue
Unread 22-02-2004, 18:15
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Things revealed by that picture:
1) "borrowed" FIRST box from Stack Attack (don't worry, I have one too...and it is in worse shape)
2) guess: ramp platform from last year (aka pizza table)
3) 9-pin box = radio, program, or tether...my guess: something else altogether
Things I can't figure out:
1) Wooden thing leaning on the wall.
2) Mechanism in bottom right corner
3) box with "G" in cabinet
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 22-02-2004, 18:54
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
It fell out of FIRST's truck and we were helping to clean the highway up.
very astute
actually, that is our yaw rate sensor.
It is a relay race course that we use in a Lego mindstorm team building challenge.
Mmmmm.... a mystery. Could it have something to do with our drive system?
It's a grape-fruit box.
Unread 22-02-2004, 20:14
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
is that the yaw rate sensor that came in the kop last year? ours looks bigger...
have you had any sucess programing it? i think its rs232 but i have no idea where to start in terms of an algorithom or whatnot. i just have no idea.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 22:07
Umm Errr...
Looks like one of our two blck boxes, only you took the time to stick on a DB-9 rather than jst drillign holz and dangling wirz out.
1139 Alumni
Unread 22-02-2004, 22:27
It's an ADXRS150 (or whatever) along with a power supply to take the battery's 12 v down to 5 v. It is, in fact, enclosed in a radio hut project box.
The DB9 is just a convenient connector to carry power in and signal out.
Unread 22-02-2004, 23:13
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
That sounds very similar to what we're doing. We used a Radio Shack project box (albeit an aluminum one) housing an Analog Devices ADXRS150EB yaw rate sensor and a Motorola MMA1201 accelerometer. Instead of using a connector, we used nylon cable grips from Digi-Key along with shielded cable to provide strain relief and good shielding without risking the addition of additional noise from a connector. The power supply (7812 regulator, voltage divider, diodes, and 7805 regulator) is housed in a separate enclosure. Yours looks a lot neater and less unwieldy than ours; I hope it works well.
Every team please read and respond! Info wanted for FIRST family tree development! Elgin Clock General Forum 99 12-01-2012 03:03
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
