Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 19-02-2004, 20:28
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Ewave Screamer with new controller?
Does anyone know if the EWave Screamer (radio modem) can be used to program this year's controller?
Thanks,
Eric.
Unread 19-02-2004, 20:38
Re: Ewave Screamer with new controller?
not the one that came in the KOP - its RS422
but I believe you can get an RS-232 radio link and use it instead of the program cable - very useful for seeing printF statements while your bot is driving around on the floor
(or you can hook several download cables together instead :c)
Unread 19-02-2004, 22:04
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I haven't tried it, but I doubt it will work. The Screamers only operate at a maximum of 9600 baud, and the IFI Loader program requires 115200 baud to download. I think you're stuck with a long cable...
Unread 20-02-2004, 16:40
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Oh, so you can't use the radio modems for misc comm stuff? We have last year's, too. I was hoping we could use those for something else...
Unread 20-02-2004, 18:21
Software Engineer
Rookie Year: 1995
You shouldn't try to use the radio modems that came in the kit of parts with anything else. They are not RS232 compatible (they use RS422 instead). Innovation First used to sell a similar set of radio modems called "Stampers" I believe which could be used for wireless download & debugging of the older BASIC Stamp-based controllers.
Unread 22-02-2004, 15:14
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
We use a set of wireless 232 modules to get data back via the programming port. The only modification you need to make is you have to change the UART boud rate to 19.2k instead of 115k.
Scooter
"Those who think that they know everything are especially annoying to those of us who do."
Unread 22-02-2004, 15:26
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
lol our team has 5 serial cables strung together that follow the robot around the room. real hitech
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 15:40
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
pppfffftt, we have 7 years worth of cables to use, we just have the freshmen team members run around and keep the cords from getting tangled.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 20:27
AKA: Jamie Bliss
Duct Tape!
Unread 22-02-2004, 23:27
boostaddict boostaddict is offline
boostaddict is an unknown quantity at this point
Scooter, where did u get these modules? I'd like to get something thats already tested to work by somebody else. thanks
Scooter
Unread 23-02-2004, 15:55
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It's kind of too late for this season, but for future reference http://www.aircable.net/ sells cables that can communicate at up to 30 ft wirelessly. One side has to be plugged into a wall, but the other can be attached just like a normal serial cable with no extra battery drain. They don't require any special configuration of the software either. I don't actually have them, so I can't verify that they are a legitimate company, but just in case anyone wants to give it a try.
Unread 23-02-2004, 16:03
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Looks pretty cool. I don't like the price much and I'm pretty confident that you could find cheaper than that, though don't quote me on that.
http://www.store.yahoo.com/aircable/aise.html
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 23-02-2004, 22:44
Scooter's Avatar
Galactic Doughnut!!
#0418 (Purple Haze)
You can get them right here.
Scooter
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Using part of last years EduRobot controller m0rph3us Robotics Education and Curriculum 0 05-12-2003 17:09
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
