Go to Post Let gravity be your friend. - MrForbes [more]
Unread 22-02-2004, 18:02
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Question Robot Controller Flips Out
We've been having a chronic -- and unreproduceable -- problem with our robot controller. Randomly, or so it seems, the robot controller's lights launch into an interesting display of lights. However, the controller is totally dead at this point.
Here are the symptoms:
The lights begin by turning off, and then a green light moves down the line one at a time. Once it hits the last LED, it turns red, and moves back up the line. Once it hits the top LED again, the whole group flashes green and then red. Then it repeats until we reset it (from the RC) or sever and reconnect the power source.
Anyone else have this problem? Ideas? Troubleshooting suggestions?
We're stuck.
Thanks for your help!
~Eko
Team 868 Programming Team Lead
Unread 22-02-2004, 18:20
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Robot Controller Flips Out
Check your main battery voltage and make sure you are using the second 7.2 V battery fully charged.
Unread 22-02-2004, 19:33
the fact that its doing a little light show makes it sound like its going into test mode - or maybe resetting?
innovationfirst should be able to tell you what that means - when you find out, please post it here so we all know what it is (just in case :c)
Unread 22-02-2004, 20:43
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Cool, can you tell me how to do it?
Maybe you got an enginneering sample.
You DID download the default code, right?
Unread 22-02-2004, 21:30
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
maybe your robot controller has managed to contract the first PICmicro virus
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 22-02-2004, 21:54
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
oh man, thats wierd, can you post a vid?
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 22:53
Following up with this, are you using the default code, or your own code? Does it occur with the default code?
Robot Controller Not Working !?!?! Team1425 Electrical 3 24-01-2004 20:52
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
Image Discuss: 810 - Minotaur: Coming to a regional near you. CD47-Bot Robot Showcase 47 25-02-2003 16:19
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
Robot Controller archiver 2000 3 23-06-2002 22:54
