Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 22-02-2004, 21:13
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: 2 questions (programming)
Rule book 4.3.1ish
AUTONOMOUS PERIOD - During this 15-second period, the ROBOTS operate and react only to sensor
inputs and to commands programmed by the team into the onboard robot control system. Human control of
the ROBOT will not be possible during this time. During this period, ROBOTS may perform any activities
that would be permissible when operated under human control. All ROBOT operation and safety rules
applicable during the operator control period are also applicable during this period.
You could test if you can get control input by creating your own competition port which is in one of the innovation first documents...
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 21:14
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
In a real match, the full competion port will be used.
Unread 22-02-2004, 21:15
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Originally Posted by jacob_dilles
when the OI is in disabled mode, the robot sees it as off and no data at all is transmited or received.
Wow ...
If you don't know the answer to a question, PLEASE don't respond.
When the robot is set to disabled mode by the Operator Interface, data IS transmitted and data IS received. The ONLY thing that is different when the robot is in disabled mode is that all PWM outputs are set to 127 and all Relay outputs are set to 0. Operator Interface inputs can still be read in by the robot.
During the autonomous period, the reverse happens -- outputs function normally, but the robot sees all OI input as 0 for switches/buttons and 127 (neutral) for joystick axes and pots.
This means, YES you can put switches on the control board to choose autonomous programs and all will work wonderfully.
Unread 22-02-2004, 21:17
Linux Guy
AKA: maxdamage
Originally Posted by KevinB
Wow ...
thats what I figured.
Human control of the ROBOT will not be possible during this time.
The way they worded it suggests that
Unread 22-02-2004, 21:19
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
okay my bad.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 23:15
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I used this last year, and I don't think it has changed at all. What you do is you grab the values of the OI autonomous selection switch while the robot is disabled before the autonomous period. Then you store it for later use. Works great.
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
3 Questions!!! (2/5/04) Andy Grady General Forum 11 05-02-2004 21:14
3 Questions!!! (1/5/04) Andy Grady General Forum 8 05-01-2004 16:01
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
