Go to Post last year's tradition is this year's rule change! - EricH [more]
Unread 21-02-2004, 14:31
kingpin3787 kingpin3787 is offline
kingpin3787 has a little shameless behaviour in the past
Pressure switch code
under which heading do we put the pressure switch code!!!!!!!!!!!!!!!!!?????????????!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
Unread 21-02-2004, 15:21
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Pressure switch code
I don't quite understand your question - do you mean which function should it go in? It really doesn't matter too much, although I think that ProcessDatafromMasterUP is the preferred place.
Unread 21-02-2004, 21:18
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
Let me see what I can do. . .
Our pressure switch code is wicked simple:
The pressure switch is on digital input 8, and the compressor is on relay 8.
in the initialization routine
relay8_fwd = 1; //Start with compressor on
In the default routine:
if(!rc_dig_in18)
relay8_fwd = 1; // If low air pressure, turn on
}else{
relay8_fwd = 0; // If high air pressure, turn off
Unread 21-02-2004, 22:14
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
if your not a fan of bulky code:
relay8_fwd = !rc_dig_in18;
relay8_rev = 0;
from there, the RC has a built in pull up on the (s) line. soo you connect the white to one side of the switch and the black to the otherside of the switch. that is, if your using a pwm style color coded cable. you dont need the positive at all. the pressure switch is N.C. meening that with this setup the normal signal will be 0 and when it closes it will be 1. therefore !rc_dig_in18 yeilds 1 when it is normal and 0 when it goes over. no if statment needed.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 21-02-2004, 22:16
FIRST Alumni
relay8_rev = 0;
bulky? I was just trying to keep it simple. . .
Unread 21-02-2004, 22:25
AKA: theshadow
FRC #0620 (WarBots)
every "if" statment is at least 4 lines in ASM. add an "else" and that adds 6 more lines. a boolean assinment is only 2 lines. but whatever
Unread 21-02-2004, 23:34
Chris Bright's Avatar
Chris Bright Chris Bright is offline
#1023 (Bedford Express)
Team Role: Webmaster
Chris Bright will become famous soon enough
Send a message via AIM to Chris Bright
correct me if i am wrong but isn't the code for the pressure switch already in the default as long as you hook up the switch to digital input 18 and the pump to relay 8?
2003 - National Rookie All-stars
2003 - Great Lake Rookie All -stars
Unread 21-02-2004, 23:48
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Yes. The default code contains the following lines, I believe:
relay8_rev = 0;
Connect the pressure switch to the white and black wires of a cable plugged into digital input 18, and you should be all set (assuming you've connected the compressor's relay to relay output 8).
Unread 22-02-2004, 10:20
There is a difference between it being easy for a human to read, and easy for a computer to understand.
Personally, I choose what is easier for me to understand, and in the 2% of cases where it needs to be fast, I write well commented assembly.
Unread 22-02-2004, 21:38
FIRST Alumni
If people ask a question, I'll give easy to understand code. I just wrote that up real quick, and didn't bother to shove it in as few lines of code as possible.
As far as four lines, six lines, or two lines in ASM- this isn't ASM.
Unread 22-02-2004, 21:46
AKA: theshadow
FRC #0620 (WarBots)
but it is compialed as such
Unread 22-02-2004, 21:52
Check out the listing of what the compiler produces. An "if" produces a bunch of assembly, but so does an assignment of bit-sized values.
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
