Re: Bouncing turns
Well, at the DC Scrimmage last Saturday, I saw quite alot of bots w/ this problem...
Luckily ours wasnt one... But anyway, the 12" pneumatics wheels seem to be used ALOT this year. Mainly, I would assume to climb the platform from the side, which based on last weekends results, isnt going to work quite as well as people would hope... We personally stick with our 8x2" wheels, spaced out 26" wide (roughly) I'm not too sure how to eliminate the issue. If you're not planning on going up the platform, try to get some smaller wheels with a little less traction. Or, you could make 2 big omni wheels for the front or back 2 tires of your bot using a bunch of smaller omnis. I would make sure your tire pressure is full though. That was an issue with a few of the 12" 4x4 bots... |
Re: Bouncing turns
someone posted earlier that they painted the back wheels with poly somthing or another. the robot will rotate around the front wheels because the back ones slip.
also with the tire pressure deflate the front ones and inflate the back ones. you want it to rotate around one wheel set and slide the other. we just stuck some casters on the back that come up when we are climbing the platform |
Re: Bouncing turns
Somoene actually suggested using a wax type substance like armor-all on the tires? Would that work, or be legal?
Re: Bouncing turns
there is another post about this(by me) but it ended up in the pnuematics section sence i said pnuematic wheels HA! http://www.chiefdelphi.com/forums/sh...ad.php?t=25061 |
Re: Bouncing turns
The Schmoebots had this problem as well. They solved it by simply removing the tires on one end and running on the rims. There's a little bit of slip from the different diameters, but it doesn't seem to cause any problems.
Re: Bouncing turns
or make a wheel outa lexan or delrin ![]() |
#7
Re: Bouncing turns
Re: Bouncing turns
Hmm. Well, I would think wax could be a bad idea, since it could(would?) rub off easily onto the carpet, something which FIRST would not like. However, what does work, is wrapping some sort of material around the tires... |
#9
Re: Bouncing turns
we had this exact same problem last year. the cause was too much top weight and too much traction. we looked like we were convulsing while turning. we could never figure out how to stop it and just kind of lived with it. on the bright side...we never lost a pushing match. good luck!
#10
Re: Bouncing turns
My team, 177, has perrenially had this issue we finally broke down and made omniwheels for the rear. Our experience shows that having lower friction in the rear wheels increases manueverabilty while retaining control compared to the fronts. Most teams who saw our bot at the UTC scrimmage can attest to it's speed and manueverabilty with these wheels. We were also never at a loss for traction.
#11
Re: Bouncing turns
<R15> Lubricants may be used only to reduce friction within the robot. Lubricants shall not be allowed to contaminate the playing field surfaces, balls, or other robots. You can use anything that will stay on your wheels, tape, paint, glue. But nothing that will rub off and contaminate the field. |
#12
Re: Bouncing turns
wax wont rub off. Though you would loose so much traction that you probably wouldnt be able to climb to the bar anymore.
#13
Re: Bouncing turns
I assume everyone is talking about 4-wheel-based bots. I guess if you were surprised that it wouldn't turn well, the lesson is to think carefully before committing to a major design decision.
Our bot has only two wheels, midship, and plastic skids on the corners. It turns nicely in any radius we choose and turns on a dime. And it can't climb the steps at all. Engineering is the art of making tradeoffs. We'll go for the bar from the side. Has anyone built a bot with a rear-end differential and steered wheels like a car? |
#14
Re: Bouncing turns
Re: Bouncing turns
It has been posted elsewhere but our team came up with it early on during the design stage once we realized that we might have some problems turning. Zip-ties on either the front or the rear wheels. On all four wheels is overkill, you may want to put them on the wheels farthest from the center of gravity of your robot in order to keep as much traction as possible.
| Disney turns away visitors on Segways | Clark Gilbert | Dean Kamen's Inventions | 8 | 19-02-2004 22:07 |
| Image Discuss: 294 Teaser, it turns? | CD47-Bot | Robot Showcase | 3 | 03-02-2003 16:56 |
| Pneumatic..Schematics..are bouncing everywhere | archiver | 2000 | 0 | 24-06-2002 00:38 |
| Bouncing heads.... | archiver | 2001 | 2 | 24-06-2002 00:14 |
| Competition Name? | archiver | 2000 | 11 | 23-06-2002 22:09 |
